So, I've been adding a quart (or two actually of 0w-40 Mobil 1 European Car Formula) every 1k miles... sometimes less. As the red light will come on in 3k miles if I fill it up and add nothing till then.
So, the engine is obviously burning oil.
Anyhow, I'm fairly busy and usually in a rush..... so I dont believe I've ever looked at the dipstick during my ownership. Regardless, looking at it today I notice the end is burnt as if no oil has touched it in a long time and after my continued efforts I can see its dry.
The sensor must work I'm assuming.
So my question is, how can I fix the dipstick or at least diagnose the problem?
The size of your success is measured by the strength of your desire, the size of your dream, and how you handle disappointment along the way.
Just wanna add, no smoke or vacuum issue.
While I should look into the oil consumption issue at some point.... the dipstick being completely dry (it is intact the plastic part at the bottom is there). Is a little disconcerting.
Make sure your oil level light goes yellow followed by red when you turn the key to start the car. Yellow is level, red is pressure. Make sure you have a correct dip stick too.
Yep, no issues there.
After reading online.... is it possible sludge has accrued at one point or another, blocking access to the dipstick?
The dipstick will punch through any gunk to reach the sump. No chance it's blocked.
I think the most likely situation is that your engine is using a lot of oil and you really are not showing on the dipstick. You should drain the sump, add eight quarts and see what the level looks like.
I would also recommend Rotella T6 5w40. You probably have dirty rings and diesel oil will clean that right up. My clapped out high mileage oil drinking M54B25 stabilized at about a quart per 2000 miles after running Rotella. Prior to that it went through at least two quarts in 1000 miles. I don't know exactly how much because I wasn't keeping track precisely. I did the same as you though, pulled the dipstick and found nothing on the end.
You're going to have to make the time to check dipstick oil levels weekly at the very least,
or every time you add fuel at most. Waiting until the warning lights are on is just foolish.
What you now save in time, you will make up in costs. Don't later say it was unexpected.
KEEP the oil levels BETWEEN the HIGH and LOW level indicators on the dipstick, unless you enjoy engine replacement!
Wait; you said the -red- oil light comes on? That means your engine is starved of oil and you should definately add a lot!
As suggested up here it's probably best to drain all the oil, fill the engine to it's specified oil capacity and then see if the dipstick is 'working' Of course replace the filter as you go. I'd personally just use the BMW spec oil, not Rotella.
No matter what I add 1-2 quarts every 1k miles. Plus, I replace the filter every 5 k and dump the old oil and completely refill every 5.
The red light comes on briefly and turns off sometimes when I'm driving....
I'm going to be out of the country Mid December to Mid January so..... I'll wait on a complete oil change until after that.
I guess I can buy the $25 5 quart of 0w-40 Euro and see if it shows up on the dipstick... if not then I'm back to square one
Add a quart at a time, checking dipstick levels after each, UNTIL the max level indicator on the stick is reached!
Then simply check daily before starting out for the day, and top off accordingly. Easy-Peasy!
Saved yourself an engine replacement, and no more uncertainties over oil level, DONE!
BTW, Fix the oil leak once located.
my 02 325ci was burning a litre ever few hundred miles. did the 02 pilot mod, which is an easy diy, and nowget atleast 1500-2000 per quart. way better. i would try that mod too.
A failing CCV system is the usual cause of excess oil consumption.
Replacement of the CCV system would be the first step I would try first,
before attempting any modifications.
