Results 1 to 5 of 5
Thread: 2014 335i high rpm hesitation.
    Nov 2018
    Orlando, FL
    2014 BMW 335i
    What’s up guys,
    Hoping someone could help me identify an issue I am having.
    Car is a 2014 N55 with VRSF intercooler, charge pipe, and catless downpipe. Tuned on MHD stage 2+ on 93 octane. Car has been running perfectly fine until today. All of a sudden while at WOT from about 5200rpm-5800rpm the car hesitates. Before and after that rpm it’s fine. Logs show a lot of timing corrections mainly in cylinder 4 in that rpm range which would lead me to believe it was a bad spark plug or coil pack. However, I have brand new spark plugs and coil packs. Not even a 1000 miles on them. Also, my fuel rail pressure in that rpm range dips extremely low. Normally it’s around 2400-2800 in that rpm range. Today it’s from 1800 to as low at 1000 in that rpm range.
    From the research I’ve done it could be anything from a bad HPFP or LPFP or bad injectors or a clogged fuel filter but I haven’t seen anything concrete.
    I woud rather not have to throw money in different parts. Can anyone guide me to what they believe the issue could be?
    appreciate any help!
    Massachusetts
    e90 with Cobb, H&R, more
    I'd lean towards a problem with the HPFP given it's known to be a problem area and more importantly you're seeing a pressure drop in your readings.
    Scott
    fast = good
    slow = bad
    See my old Porsche here...
    Nov 2018
    Orlando, FL
    2014 BMW 335i
    Quote Originally Posted by teflonjones View Post
    Appreciate the response. Do you know of any other symptoms I would be seeing with a bad HPFP aside from the hesitation I’m getting in that rpm range?
    Mar 2019
    Southern wisconsin
    12' vw CC, r32, f30 335
    Quote Originally Posted by CarbonF30 View Post
    I'm currently having the exact same problem. I also have the same exact mods as you. Did you ever find the fix?
    Apr 2020
    California
    2015 f30 335i msport
    Quote Originally Posted by Bimmergeek335 View Post
    Having same issues what was it ?
  1. 1995 M3 Dinan Supercharged, Stg. 1, high RPM hesitation
    By wsybert in forum Forced Induction
    Last Post: 09-11-2015, 08:35 AM
  2. Replies: 8
    Last Post: 06-19-2009, 06:38 PM
  3. High RPM Hesitation/Stumble
    By RUddin3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-21-2005, 11:27 PM
  4. Car hesitates at high rpms
    By jafo in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2005, 11:01 AM
  5. 97 328i Hesitation on Acceleration at high RPM
    By amarkuze in forum 1991 - 1999 (E36)
    Last Post: 11-27-2002, 01:20 PM
