Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: 3K 535i Project
  1. #26
    Feb 2019
    USA
    2007 BMW 530xi
    This is beautiful
  2. #27
    Mar 2011
    Dallas, TX
    2008 535i
    While waiting on more parts I worked on the harness. Stupid crank sensor plug snapped in half. Ordered a new connector and crimped new pins.
    All done.
    Suspension parts started arriving. Got Koni Actives, new strut mount, new swaybar endlinks and lower control arm. Thrust arm looks ok, so I did not order one.
  3. #28
    Mar 2011
    Dallas, TX
    2008 535i
    My turbosmart diverter valves and new charge pipe showed up today. Also picked up a new spring compressor, tired of using the deathsticks. I can remove springs in 30 seconds now
  4. #29
    Mar 2011
    Dallas, TX
    2008 535i
    Started assembling the suspension. Got all the pieces for the struts. New spring pads, bellows, bump stops and strut mount.
    Old and Busted
    New Shiny
    All put together.
  5. #30
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What brand and model is the strut tool?
  6. #31
    Mar 2011
    Dallas, TX
    2008 535i
    https://www.redlinestands.com/catalo...pressor-p-1593
  7. #32
    Mar 2011
    Dallas, TX
    2008 535i
    My GAS monoballs arrived. Even though my thrust arm looked ok, I got new one just for piece of mind. This was the last piece I needed to finish the front end.
  8. #33
    Mar 2011
    Dallas, TX
    2008 535i
    Got most of my CIC / combox / logic 7 retrofit as well. I was originally going to go aftermarket, but the prices for the oem stuff are so low it's a no brainer. I got most everything for $600 total. Just need to buy logic 7 subs and get couple connectors to build a harness for the combox.
  9. #34
    Mar 2011
    Dallas, TX
    2008 535i
    Got a bunch of stuff done on the car.
    Got the motor installed.
    Most everything reconnected
    Got my PSP 600 Intercooler hooked up. Very happy with it, very good fitment, uses factory mounting points. Built in bracket for transmission cooler.
    Fitment is good
    All put together
    I neeed to fix one of my axles, it had a torn boot. I tried removing it and it was such a pain in the ass. With a huge puller I finally got it out, but it collapsed a few threads and I could not get a axle nut on it anymore.
    Ended up getting a new GKN Axle, only $180 so not too bad for OEM quality.
    I drove it car a bit, but was getting a couple transmission codes related to the valvebody. It was the last straw for me, I wanted the manual swap anyway, so I was just looking for any excuse to throw the autobox in the garbage lol.
    I picked up a 6MT and I am in the process of doing a manual swap.
    New Trans!!
    Pedals out!
    New DMF Flywheel
    New 335is clutch, should be good for 550hp.
    New seals for the trans, flywheel bolts, bellhousing bolts. Some synchromax fluid. Upgraded pivot and new shifter bushings.
    Can't forget new ZHP Shiftknob
    While waiting on some parts, I got the CIC retrofit done. The coding was a total pain in the ass, I used the patcher method to generate my own FSC certs so I didn't have to use any emulator. FSTOOL is worst piece of **** software ever, took me like 3 days to get it working. I also installed combox, so now I have bluetooth streaming. Combox is tricky since there is no vehicle order for it on a E60, you need to create a custom sdd file and use a E90 vin and manual code it. After some trial and error I got it all working.
    I am in the process of installing the logic 7 speakers and amp. I am using a technic harness to tap speaker inputs at the cic, so I don't have to run all new speaker wires for the new amp. Just waiting for a pin extractor tool so I can redo the amp harness.
    I also ordered a 3.08:1 rear diff to better match the transmission, auto diff is 3.46:1.
  10. #35
    Jun 2005
    New England
    This is a very impressive build. I continue to be amazed. You might have more than $3k in it when you are done but it will be an awesome car.
  11. #36
    Mar 2011
    Dallas, TX
    2008 535i
    That is how it goes, buy BMW for 3K and spend 6K to make it run good lol
  12. #37
    Mar 2011
    Dallas, TX
    2008 535i
    Got few things done in the last few days.
    Found some aluminum trim, was getting tired of the wood.
    Got the clutch installed
    Pedals installed
    Clutch line done
    Transmission installed
    Shifter linkage
    Shifter in the CAR! shifts so nice
  13. #38
    Mar 2011
    Dallas, TX
    2008 535i
    6MT Swap all done, finished CIC swap as well, so I could put the interior back together. Got all the Logic 7 speakers installed and got the aluminum trim installed.
    Found a local M5 owner selling his old set of wheels. ACE Design AFF05 flowform. 20x9 fronts and 20x10.5 rears. 20 offset both. Extra set of rears as well. Tires are Pirelli Pzero 255/35/20 and 275/35/20.
    Front might rub a bit, but once I roll the fenders it should be ok. There is like barely any clearance between strut and tire, but it fits
    Washed the car and got the wheels installed. Now just need M sport bumpers.
  14. #39
    Aug 2012
    Simi Valley, CA
    328, 525, 740, R1200RT
    And???
  15. #40
    Aug 2001
    Utah
    A Few Too Many
    Man. This was a great read.
  1. E28 1988 535is -"project" in Cincinnati - $600
    By Drew in Ohio in forum 5 series & 6 series
    Last Post: 02-15-2010, 07:57 AM
  2. My E34 535i "project"
    By zener in forum 1988 - 1996 (E34)
    Last Post: 09-02-2008, 02:22 PM
  3. Help! e34 535i project
    By otee30 in forum 1988 - 1996 (E34)
    Last Post: 02-25-2008, 04:12 PM
  4. 535i Project or Parts
    By blue34 in forum BMW Parts For Sale
    Last Post: 04-06-2005, 10:27 PM
  5. BMW 535I Project - Needs Paint! Cheap!
    By blue34 in forum BMW Cars For Sale / Wanted
    Last Post: 04-06-2005, 08:50 PM
