Results 1 to 10 of 10
Thread: Help with Ike voltage issue 2001 740
    Nov 2018
    Atlanta
    2001 740i
    My 740i has a lot of intermittent IKE display issues. When I do my IKE test 9 I get 6.9 volts while the battery tests normal at 12.5
    I know the I bus needs above 7v for reliable data comms and that the IKE is both a multibus gateway and a standby controller and voltage supplier for the I bus.
    Is this the problem? Can I do anything other than replace the LCM ( I bus master controller) and IKE?
    Are there any other options? Maybe the ignition switch is not providing proper voltage to the IKE?
    Any ideas on troubleshooting?
    john
    2001 740i
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by Ltbordo View Post
    Is is this the problem? Can I do anything other than replace the LCM ( I bus master controller) and IKE?
    Are there any other options? Maybe the ignition switch is not providing proper violate TO the IKE?
    john
    2001 740i
    After the battery, I would replace the ignition switch whenever there is a voltage issue.
    Nov 2018
    Atlanta
    2001 740i
    Battery and ignition switch tests good. Voltage with engine running is 13.5 and ignition switch output on all three output terminals is the same after engine is started at 13.5 Volts as well.
    Can’t figure out why IKE test 9 voltage is so low!! The manual says that test 9 is battery voltage but could it be the generated bus voltage from the IKE gateway ? The manual says that gateway needs above 7 volts for reliable communication on the I and K busses
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    IKE Test 9 is the voltage from Terminal 15 - the voltage supplied when the key is in position I (accessories) - it doesn't measure I-Bus voltage, it measures a DC voltage presented to either the MID or the IKE depending on model. It is a strange reading, but probably nothing to worry about unless you have operational issues....
    My BMW Repair YouTube Channel
    Nov 2018
    Atlanta
    2001 740i
    Lots of operational issues! The worst being intermittent trans fail mode. As well as tons of MID display issues. Where is terminal 15 ?
    john
    Ps my model is a 740i sport model with winter package
    Vin WBAGG83481DN87322
    Nov 2018
    Atlanta
    2001 740i
    I tested the ign switch output when in ign switch position 1 (fist click clockwise) and it read battery voltage!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Tell us what problems you have - and then we will be able to give you better answers - when do you get TRANS FAIL-SAFE PROG? What other problems do you have?
    There are three basic voltage supplies (on all BMW models) Hot at all times (permanently live, not switched) - Terminal 15 (power supplied in key position I) - and Terminal 30 (power supplied when the key is in position II) - they do not relate to physical 'terminals' as such....
    Nov 2018
    Atlanta
    2001 740i
    Thanks TIMM (btw chris kethan sends his regards and thanks for past help given)
    problems are intermittent ie about 2% of the time MID display on cluster works perfectly and when it does test 9 is always above 7volts
    sometimes display is blank but when sun is at a certain angle I can see MID info displayed
    sometimes display is full bright but “frozen” ie shift selector shows d when in park or vice versa. Also when this problem occurs the seat belt will show as plugged in when not plugged in or vice versa. Also in this problem mode the shift selector info will stay on when key removed
    sometimes especially recently the trans will be stuck in a gear and not shift, if the display is in bright mode it will show trans fail program mode on engine shutdown. Typically on restart trans works perfectly
    sometimes on start all lower cluster and MID including check engine light and low fuel light will stay on frozen until engine shutdown
    on all problems when the display is visible the test 9 voltage will read below 7 volts. When it works fine it will show more than 7 volts. There have even been a couple of times when everything “sort of” works and it will slowly but correctly show from p to n to d in the shift selector and slowly but correctly change from seatbelt connected and disconnected and then test 9 will be right AT 7 volts!!
    range of voltage readings on test 9 has stayed between 6.5 and 7.4 volts. Battery always is around 12.5 engine off and 13.5 engine running. Output voltage from ignition switch has always tested good with similar voltages.
    very strange and hard to trouble shoot.
    John
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Did you check all the voltages from the ignition switch? There are four outputs from it - and any of them can cause problems.
    Nov 2018
    Atlanta
    2001 740i
    Yessir. I saw 3 thick wires and one thin trigger wire for the starter crank signal. The 1st wire was 12v in position one and all three thick wires showed 12v in position 2. The trigger wire got 12v in the spring opposed start position 3
  1. 2001 740 IL engine fault help!!
    By jmac510 in forum 1995 - 2001 (E38)
    Last Post: 01-18-2011, 09:17 PM
  2. Thinking about buying a 2001 740... Need help!
    By shubbardman in forum 1995 - 2001 (E38)
    Last Post: 08-02-2009, 10:04 PM
  3. help!! 2001 740 i brakes
    By rodrigofome in forum 1995 - 2001 (E38)
    Last Post: 03-29-2008, 11:13 AM
  4. Coding issues .. help with IKE?
    By BayernKiwiBMW in forum 1996 - 2003 (E39)
    Last Post: 08-29-2007, 11:37 PM
  5. 2001 740 Navigaion Issues
    By Traveller in forum 1995 - 2001 (E38)
    Last Post: 12-11-2006, 10:14 PM
