Results 1 to 15 of 15
Thread: 98 E36 M3 Engine Issue - Loss of power, miss fire Cyl 3
    Jul 2015
    1998 BMW M3 Sedan
    Hi everyone,
    My issue started on the freeway going around 65mph, suddenly I had a loss of power. It wasn't a full loss of power but it suddenly had no go, along with this there was what I can best describe as a ticking noise from the engine that got quicker relative to rpm (higher rpm quicker ticking noise). In first gear I had no torque at all and second gear was the go to (this was once I got off the freeway and was pulling into a fuel station).
    Since that happened I have replaced the spark plugs, replaced the coils as well as the post-cat O2 sensors (these were all things that I had already planned on doing and was hoping it was related to one of these). I checked the code reader and I got the code of a misfire in Cyl 3 now. I am thinking it's possibly a valve issue but wanted to get feedback on what test I should do next and what the best direction to go in would be.
    Here is a video (excuse the dust I left the hood open while working on it and somehow it became a dust magnet even though it's in the garage)
    Apr 2015
    Tennessee
    1998 BMW 328i
    Sounds like a valve lifter tick to me.
    Jul 2015
    1998 BMW M3 Sedan
    Quote Originally Posted by XnWarden View Post
    Thank you appreciate the quick reply, going to do some research on that now.
    Jun 2010
    NY
    1997 328i
    You have to hook up a gauge and do a fuel pressure test.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to M3 forum
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    First thing I'd do is a compression test, followed by a leakdown test. If you can't do it, pretty much any good shop could do it.
    But from your description, I'd say you have a dead cylinder. But that's just a WAG (wild ass guess)
    Dec 2005
    Virginia
    1997 M3, 2012 C63
    Check the oil level? I had a similar sound once and my level was below the markers on the dipstick (stupid me for not checking it more often). Sometimes it's the simple things.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Do a hard reset by unplugging the battery and plugging it back in. Ecu can adapt to a bad coil and keep it from igniting later to avoid catostrophic misfire. Also, i would check the compression specs, and swap the injector to see if it fallos that if the compression test comes out fine.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by KestrelProdigal View Post
    Did you miss a shift? Compress test is the next thing you should do.
    [IMG][/IMG]
    Jul 2015
    1998 BMW M3 Sedan
    Quote Originally Posted by RRSperry View Post
    Thank you, these were the two tests I was thinking of running next based on some research.
    Quote Originally Posted by Eric93se View Post
    Ok thanks, if the compression test and leakdown don't lead to a fix I will try this next.
    Quote Originally Posted by realjones View Post
    Yes I was hoping this was the case as it happened but the oil was at the perfect level :\
    Quote Originally Posted by spyderg0d View Post
    Thanks I did do a full reset a few times to make sure and it didn't change anything. Will swap the injector when doing compression test and see what happens.
    Quote Originally Posted by AJLM34A View Post
    No I didn't miss a shift, it happened under normal cruising speed and load. Thanks going with compression test next.
    Jul 2015
    1998 BMW M3 Sedan
    Ok got preliminary test results back. Low compression on both cylinder 3 & 4, other cylinders checked out fine. Sounding like a gasket issue perhaps but will know more tomorrow. Anybody else experienced something similar?
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Yes, but it was a misfire on #6. I had low compression on 5 & 6 and found a Vic Rentz head gasket. I bought my car with 92k miles on it and the gasket went at 103k. Use an Elring head gasket.
    [IMG][/IMG]
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    I lost mine between 5 & 6 too at 145k miles.
    No coolant leak, or mixing with oil, or pressurized coolant system. Just a leak between 5 and 6.
    As far as head gasket failures go, it's about the best way to lose one.
    My guess is if you do the compression test the right way (remove all spark plugs) you'll get zero on the bad ones.
    It's not too hard if you can follow directions. That was 90k miles ago for me, and no problems.
    Jul 2015
    1998 BMW M3 Sedan
    Quote Originally Posted by blckstrm View Post
    Great thanks, I have seen a few how to's on replacing head gaskets. Do you have a preferred one you would suggest?
    Jul 2011
    Austin, TX
    I had read the same things as everyone else. I bought a Victor Reinz kit and a standalone Elring HG. That was the cheapest way I found to get everything I needed.
  1. E36 98' E36 M3 Engine Harness
    By Daz4life in forum Engines, Performance Parts & Software
    Last Post: 09-13-2011, 04:48 PM
  2. Replies: 30
    Last Post: 12-17-2007, 05:34 PM
  3. Replies: 1
    Last Post: 12-14-2007, 11:14 PM
  4. DC/VA/MD E36 M3 Engine Cover (BMW M POWER) (Local only)
    By Motorsport333 in forum Exterior Lighting & Body Parts
    Last Post: 10-30-2007, 10:04 PM
  5. 97 m3 engine ticking - loss of power
    By liquidryder in forum 1992 - 1999 M3 (E36)
    Last Post: 07-11-2006, 01:25 PM
