Results 1 to 13 of 13
Thread: Help selecting proper head gasket
    Oct 2018
    Eugene
    Working on it
    I am building an m50nv turbo set up. Bored to 84.5mm, decked .006, and mated to a cylinder head that has been resurfaced. I have wiesco 8.8:1 pistons and stock length eagle h beam rods, along with ARP headstuds. Wanting to run a gt35r at about 15-18 psi daily.
    I believe that I want a cut ring head gasket but don't know what thickness to get. Any suggestions on brand or thickness would be appreciated.
    Thanks,
    Reed
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Since you have low CR pistons buy a standard thickness HG.
    Oct 2018
    Eugene
    Working on it
    I'm leaning toward a CES HIGH BOOST CUT RING HEADGASKET. Any other recommendations?
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    For pump gas get the 84.5MM cutring and lower your compression with the copper spacer option - for e85 do not get a spacer
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
    Apr 2006
    Minnesota eh?
    86 325es
    Get stock thickness and 85mm bore.
    https://boost-monkey.com/cut-ring-he...p-to-85mm-bore
    Jun 2005
    New England
    JE or Athena are your cutring options.
    Oct 2018
    Eugene
    Working on it
    I thought with the lower compression that I shouldn't run e85?
    Apr 2006
    Minnesota eh?
    86 325es
    You don’t need the spacer because you already have low compression pistons. I think the person in post #4 missed that. E85 works fine with low compression but you should be fine with 93 octane.
    Jun 2005
    New England
    The OP has wiseco 8.8 CR pistons. He does not need a thicker HG or spacer.
    Nov 2013
    VA
    E36
    ^correct. Just run the CES cutring w/o spacer. Stay away from MLS head gasket. I'm not too familiar with e85 but I always thought it was more advantageous to keep stock compression...You already have low comp pistons so I don't think e85 is the best route for you.
    Apr 2006
    Minnesota eh?
    86 325es
    E85 will work fine with low compression, there just isn't really a need for it until your going for 20+ psi of boost.
    Oct 2018
    Eugene
    Working on it
    93 was my plan. As far as gasket dimensions go, both 84.5mm and 85.0mm have been suggested. I assumed I would want to match the head gasket to the engines bore. Any reason you suggested 85.0 Someguy?
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by E30round2 View Post
    I have an 84.5mm one on my 84mm bore motor and there is absolutely no room for error to get the rings centered on the bore when you put the head on. If a ring shifts slightly when you set the head on you'll have a ring overhanging the bore. For this reason if I ever buy another one I will always get one at least 1 mm over bore diameter to give myself some margin for error. There will be no detrimental effect from getting one a little bigger than bore diameter.
  1. Replies: 13
    Last Post: 09-13-2011, 10:44 AM
  2. HELP<is my head gasket toast? e36 325i
    By pikey888 in forum 1991 - 1999 (E36)
    Last Post: 09-23-2009, 07:37 PM
  3. need help determining possible head gasket failure
    By ///Mracer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-15-2008, 09:17 PM
  4. Need help selecting a Head unit
    By conway in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-30-2007, 10:52 PM
  5. Replies: 6
    Last Post: 02-02-2007, 10:28 PM
