Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Installing Continental TR7412UB- OR... Adapter harness?
  1. #26
    Jul 2016
    NH
    Z3 3.0 - X1 35i - X1 28i
    Ok guys,
    I've installed a lot of stereos in my day, but this one is pissing me off. While installing the TR7412UB-OR in my 2001 Z3, it lights up, but no sound from the speakers. The amp works fine when I install the stock stereo or an aftermarket Sony, but no sound from the Continental.
    I'm using a Metra 71-1784 on the stereo side and a Metra 70-8590 on the Z3 side.
    When hooking the wires up, I'm going color to color, but there is a blue and a blue/white on the stereo side and a blue on the Z3 side. Am I connecting the solid blue to the solid blue or is it the blue/white to the blue on the Z3?
  2. #27
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    1st you/we need to know what’s what before being able to answer. My initial guess would be something to do with amp switched power (not main power). Afaik it’s a white wire at the amp
  3. #28
    Jul 2016
    NH
    Quote Originally Posted by z3forlife View Post
    So you've hooked one of these up?
    Like I said, I am using pin for pin wire harnesses and when I do this for the Sony without any additional wiring, it works fine. This is a TR7412UB-OR specific question.
  4. #29
    Aug 2012
    Kansas
    Which pin are you referring to. There’s a A & B plug used.
  5. #30
    Jul 2016
    NH
    From the TR7412UB-OR
  6. #31
    Aug 2012
    Kansas
    You would need to refer to the pin outs for both the Sony and the continental. If both are identical then I’d double check the splices. Can you identify the pin number I haven’t found a schematic for the harness yet
  7. #32
    Jul 2016
    NH
    Just took a meter to every wire and no dropoff from bad splice.
  8. #33
    Aug 2012
    Kansas
    See if the amp remote on (white I believe ) is hot at the amp. So no sound when you use any of the inputs on the continental? Which pins are the blue & blue/white on each adapter
  1. 6pt Harness Install on VAC seat adapters
    By chad97m3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-29-2011, 02:44 PM
  2. E36 Adapter Harness
    By Beerplease in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-20-2008, 01:48 AM
  3. Amplifer adapter harness?
    By nick325xit 5spd in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-23-2007, 10:49 AM
  4. Replies: 9
    Last Post: 04-13-2007, 03:43 PM
  5. Installing Auxiliary audio input adapter.. help
    By msund15 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-27-2006, 09:16 PM
