Results 1 to 25 of 33
Thread: Installing Continental TR7412UB- OR... Adapter harness?
    Jul 2015
    Shoreline Wa
    M Coupe, A4 Avant , MGB
    Ordered a Continental TR7412UB- OR, will be here tomorow... went to a local car stereo shop and get a Metra harness and it has only constant 12v, switched ignition 12v, amp turn on 12v, chassis ground and then 4 RCA jacks for front and rear speakers. There are way more wires into the harness on the car then the Metra one... and also the Continental radio has no RCA outputs.
    So I’m guessing I’m missing the illumination, headlight dimming, speed sensitive volume, sub out, and some other things... is it going to be easier to just cut off the factory plug and wire everything to the harness for the continental unit? Has anyone installed this unit in their z?
    Also, what is this white connector at the bottom of the main connector?
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    I used Metra 71-1784 (radio side) and Metra 71-1784 (car side) and it works great.
    Jul 2015
    Shoreline Wa
    Thanks, what was the part number for the car side? You have the same part number for both.... Im guessing they should be different?
    Jul 2015
    SoCal
    1999 BMW M Coupe
    Someone on FB mentioned that you only need Metra 70-8590 .
    I have also bought the unit, and would be interested in the correct connections.
    Jul 2015
    Shoreline Wa
    I should note that I have the harmon kardon emblem on the sub box which im asuming means that its the factory amplified system... the Metra harness I got is 70-8591 which is the bmw amplified integration harness. (Which is the one mentioned above with too few wires and rca outs)
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    Quote Originally Posted by Ring Rat View Post
    The white connector is for the CD changer, normally mounted in the trunk. Some aftermarket interface units use it for an aux input, fooling a CD43 or C33 into thinking it is the CD changer.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by doclip View Post
    My mistake, the harness for the car side is Metra 70-8590
    The radio side is Metra 71-1784
    I wired in my own adapter using generic ISO radio harness adapter and a BMW radio harness plug adapter. Match wire colors, splice, done.
    Ill also gonna be putting mine up for sale soon. Bit less than retail though I could definitely still return it "as new" ...just not a fan of the mismatch illumination color. Im gonna set up an aux in to my CD43 instead
    PRICE CUT on ALL FABRICS
    Jul 2015
    Shoreline Wa
    So then is the amp turn-on wire not required? Also, if there are only 4 audio outs is that all that is on the harness for the car? If the sub just wired into the two rear speaker from the factory?
    Jul 2015
    Shoreline Wa
    https://i.imgur.com/blkoTSAr.jpg">
    Well can confirm that just wiring up the Metra 70-8590 works fine. Got it up and running and am thrilled with the sound and look of it when the lights are off. Light on.... what a drag. The color is more off than I thought, but I can live with it. CD 43 is too expensive, Clarion m508 has white lights, and everything else looks like an alien device.
    Thanks for the help!
    Jul 2015
    SoCal
    1999 BMW M Coupe
    What connector did you use for the radio side?
    Jul 2015
    Shoreline Wa
    I used this one:
    https://www.ecstuning.com/b-vdo-part...slash-330~vdo/
    was suggested when i picked the radio from their site. Worked great.
    Universal ISO
    Think this was the exact one I used in fact: https://www.amazon.com/Universal-Har.../dp/B00ZCO8GOQ
    Its.not rocket surgery guys, high school dropouts can figure this stuff out at your local car audio install shop...
    Universal ISO radio harness on the radio side
    BMW radio harness adapter on the car side
    Jul 2015
    SoCal
    1999 BMW M Coupe
    Great!
    That's what I thought too.
    My main reason to buy this radio is the ability to connect a usb drive.
    I'll try to get it installed too.
    Tallahassee
    1998 Z3 M Roadster.
    I have the same unit.
    Like it better than my previous bling Kenwood.
    Color, well it’s close enough for my taste.
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    Where is it possible to purchase a Continental head unit in the states? I've looked, and no one I know stocks the brand.
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    Quote Originally Posted by Mark Bielick View Post
    ECS tuning has them, decent prices too. They have a couple different models and the harnesses.
    https://www.ecstuning.com/b-vdo-part...7412ub-or~con/
    For example. Note I am not affiliated with ECS, just trying to provide an answer.
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    Thanks. I've bought from ECS in the past and had no issues. Good company.
    Ordered the head unit today. I'm replacing a high end Kenwood unit that goes on the fritz at random times, and is never readable in any type of bright lighting. I'm sure I will have questions wiring this unit.
    Thanks for the link.
    Mark
    I have one for sale with an adapter if anyone wants it. I just decided to keep my radio stock
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    Wish I would have known that a few days ago. I would have bought the unit from you.
    Did you have the unit installed in the car? If so, was the screen legible in high sunlight? That is the main reason I am replacing the Kenwood I have now. In the sunlight, it is totally useless because no combination of color or contrast can make the screen legible. I want to be able to push a button to get what I wanted out of the stereo, not stare at a useless screen.
    Just a quick question, What wiring adapter did you use? The one I'm going to try is:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Not sure if it is the correct one or not.
    Thanks,
    Mark
    Actually, after re-reading the threads, you did say you might be selling yours. I should have read closer...
    Thats also the exact adapter Iinked earlier
    Thats half the puzzle. Youll also need the BMW part of the adapter. Then you just wire them together
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    It's the only one I could find for the ISO units. I thought it should work here.
    Since I wired in the Kenwood using an adapter to fit the BMW plug to the Kenwood, I was hoping to use the same adapter for this install. Just replace the Kenwood side with the new unit side.
    The only issue I have is the Kenwood unit had wiring for a subwoofer, and the new unit is only 4 speakers. Not sure how that is going to work.
    Mark
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    What amp are you using
    Aug 2013
    Terre Haute Indiana
    1998 Z3 2.8
    With the Kenwood, I just used the HK amp. Sound was OK, as long as the volume wasn't cranked. Not sure what I want to do this time. The sad part is, the head unit has enough power to run the speakers on it's own. 4 x 41 W. Do I really need to run anything through an amp with this system?
    Aug 2012
    Kansas
    It would be nice to make a bridge adapter to eliminate the amp then you’d be all set. If you could find a bad amp to salvage the plugs from and the correct schematic from wedophones manual page then it shouldn’t be too tough. I’m not sure if the stock unit had a separate sub circuit to the amp or if the amp pulled signal from the rear channel. My alpine amp can work either way. Luck for me the PO ran two rca cables to the trunk.
  1. 6pt Harness Install on VAC seat adapters
    By chad97m3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-29-2011, 02:44 PM
  2. E36 Adapter Harness
    By Beerplease in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-20-2008, 01:48 AM
  3. Amplifer adapter harness?
    By nick325xit 5spd in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-23-2007, 10:49 AM
  4. Replies: 9
    Last Post: 04-13-2007, 03:43 PM
  5. Installing Auxiliary audio input adapter.. help
    By msund15 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-27-2006, 09:16 PM
