Results 1 to 25 of 37
Thread: bmw seat inside the house(need advice)
    Nov 2018
    Lithuania
    e39 530d
    im making a present for my brother this christmas. Im custom building a computer gaming chair using e39 comfort seat. my father is a carpenter and generally a handy man, so i have frame and armrests covered. however neither of us has a clue how to connect the electrical wiring. the question is how do i connect the seat in order controls to work. I already figured out how to get the conversion from 220v to 12v. for that im going to use my old laptom charging cable i was told it should work. The main thing i need help with is figuring out where to connect all those wires to.... do i simply need to find the + and -? (since i dont need all those seatbelt tensioner and occupation sensors) this is too complicated to form a question, my head is hurting from all the research😫
    for some reason i cant upload pictures here..
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    use a free pic upload service and post the link here
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Your laptop power supply many not put out enough current for the seat motors.
    Are you trying to use the BMW seat switches?
    You could just get some DPDT toggles switches for each motor and eliminate all of the BMW switches.
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    I think you need a transformer that you connect the 12v side to the - + in the chair and plug the other end into the wall.
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
    Jan 2015
    Shreveport Louisiana
    ive got to agree with jimlev's concern that your laptop power supply wont supply adequate current to drive the motors, if i was attempting this, i'd either use a battery to drive the motors, with a charger attached for it, or step up to a properly rated power supply.
    it will require more than just a transformer to accomplish this, rectification needs to be done to convert ac to dc voltage
    JimLev's Avatar
    Sundance Mesa, NM
    Ernest, you need something like this for the seat motors.
    120/220 input with 12v/30Amp output.
    https://www.amazon.com/SUPERNIGHT-Un...t+power+supply
    San Jose, CA
    1997 BMW 540i 6 speed
    Pin 5 (+) and pin 6 (-) at the seat control panel. https://www.newtis.info/tisv2/a/en/e...stment/ndkfJlU
    Jim is correct. You need a hefty DC supply. Be sure to fuse the output.
    Good Luck if you don't have the control panel!
    JimLev's Avatar
    Sundance Mesa, NM
    The seat control panel would be the easiest, only 2 wires to connect.
    Otherwise a DPDT switch on each motor to control motor direction.
    So your building something like this? From the Unser Racing Museum today. (Not me in the seat)
    When it was my turn I did 206 MPH around the track without crashing.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Hah, I've seen those simulators at some automaker events, too. RFactor 1 is pretty old at this point.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Nov 2018
    Lithuania
    e39 530d
    I was surprised how many responses i got here! thank you so much for your advices. Indeed as some of you were saying the laptop thing doesnt work in this case. i went to the electronic store andbought this little thing(slightly larger than the box on laptop cord) that changes the voltage to 12V. i plugged it into the wall and the 12v output i just guessed and conected to the thickest cables sticking out of the seat and it works! all the controlls work! thank you so much for your replies, looks like i stumbled into a friendly community. I'll work on uploading some pictures of this project(the way Shogun adviced)
    Nov 2018
    Lithuania
    e39 530d
    thanks for advice, i just signed up for "dropbox". trying to figure out how it works
    you were right about the power supply. I got the proper power converter. just plugged the 12v output to the thickest wires coming out of the seat. there is a slight delay after you press one of the switches but its not too annoying. thank you for your advices, i really appreciate that.
    Feb 2012
    Croatia, Split
    1997 e39 540iA
    As edjack already described in post up, you just need to connect power supply of stable 30A 12-14,4 VDC on pins.
    All modules are inside seat so it will all work.
    for Seat heating you need to add aditional switch only to activate it.
    From which year is seat? pins could be different
    Nov 2018
    Lithuania
    e39 530d
    you are right about laptop thing was aqd idea. i dont know what rectification is but a guy in electronic store gave me this converter thing. its a black box that converts electricity to 12v. it does some other thing which i dont understand but the end result is that the controlls are all working! oh that converter cost me 36€) so far two front seats and the converter added up to 106€.
    CaleCro you are right. with the right power output it all works. im not sure what year the car was.. the seats are actually from bmw e38, but i have the exact same ons in my e39. anyways the controlls work, im super excited!!
    Nov 2018
    Lithuania
    e39 530d
    this is the link to some pictures of my project if you guys want to see it. Looks weird now but just wait, i have it all in my head, its going to be great, i promise!
    https://www.dropbox.com/sc/l7tdraim0...tqscTnEdJnP3ha
    JimLev's Avatar
    Sundance Mesa, NM
    Looks good, nice woodworking tools.
    One problem, we don't see any empty beer bottles in the pics, lol.
    Let us know when you add more pics.
    Jan 2015
    nice mortise and tenon work...its becoming a lost art
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    LOL. Cool thread. Yep - I cut an underseat plug out of a junkyard car so I can plug in a seat in the basement quickly without any fuss and power it around. I also found problems if I don't give it enough juice... I think the control module might measure voltage drop because if it doesn't have enough juice it doesn't even really move a little they just don't work at all. But give it enough power and the seat will work just like in the car.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I saved a drivers seat out of a 2017 ScoobyDoo WRX in which the seats airbag went off, I saved it figuring that I’ll turn it into an office desk chair. I already got the base off of an old desk chair, the hydraulics still work great, I did order a set of 5 rollerblade type wheels, bearings and all off of eBay made to go right into the mounts replacing the desk chairs stock wheels. I gotta figure out how to restitch the seats side where the airbag ripped on thru. Shouldn’t be that hard, I’m sure a moron like me could figure out how to do some stitching.
    Nov 2018
    Lithuania
    e39 530d
    here is the link again. Made the frame and atatched the armrests. Looks weird and boxy, but stick with me, it will look better. I still need to make some adjustments..
    https://www.dropbox.com/sh/kq9mitu7j...ASI-xo1Ka?dl=0
    JimLev's Avatar
    Sundance Mesa, NM
    Looks good. Is that oak your using?
    Mar 2010
    Cool. Wood kinda has that green look of some poplar. Doesn't look oaky to me... Could be some euro variety of wood we dont have?
    2003 M3CicM6 TiAg
    Former:
    Feb 2014
    Alexandria, VA
    I thought poplar too.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Like an ash or something.
    Nov 2018
    Lithuania
    e39 530d
    philly98540 you are right! this is ash. im not going to leave it this color though, my dad has a bunch of cool dyes (its not exactly a dye, its like a colored oil you rub into the wood, and then whipe off the surface dry, while the oil soaks the wood) sorry english isnt my first language. i just uploaded a picture with the different paints. me and my father agreed that the darkest color(moorish teak) would look best. what do you guys think? (the leather is going to be black)
    Nov 2018
    Lithuania
    e39 530d
    oh im sorry, i forgot the link. here it is:
  1. Taking a 2000 BMW 328CI for inspection tomorrow need advice
    By anthonyfordf150 in forum 1999 - 2006 (E46)
    Last Post: 08-31-2011, 10:57 AM
  2. New BMW Owner - Saying hello and need advice
    By deccandreams in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-27-2010, 02:11 PM
  3. heated seated just went out...need advice.
    By adxss in forum 1991 - 1999 (E36)
    Last Post: 11-25-2007, 11:01 PM
  4. Seat tilt in convertible -- need advice!
    By Sailor in forum 1999 - 2006 (E46)
    Last Post: 01-27-2005, 12:43 PM
