Results 1 to 5 of 5
Thread: Radio Connector/Harness Differences
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    There are differences between the car radio connector pins and the radio harness:
    1) Different number of pins: 15 slots in the car connector & 13 pins in the harness. What is missing in the harness?
    2) There's a white connector in the car connector (lower left) and nothing matching in the harness.
    3) Does anyone know what the individual car connector slots are for?
    car radio connector.jpg Car connector
    radio harness.jpg Harness
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by radlaw View Post
    For the pin layout see Timm's picture. Here are the English translations:
    1 Front left speaker +
    2 Front right speaker +
    3 Rear left speaker +
    4 Telephone mute
    5 Switched +12V
    6 Rear right speaker +
    7 n/a (*1)
    8 Front left speaker -
    9 Permanent +12V
    10 GAL speed signal
    11 Front right speaker -
    12 Rear left speaker -
    13 Illumination
    14 Rear right speaker -
    15 Ground
    16 Remote power for antenna and audio amplifier
    17 n/a (*2)
    (*1) Pin 7 is the I-bus. While the E31 technically has the I-bus (in fact it was the first BMW vehicle to be equipped with it) it was implemented at a small scale and is slightly different from the I-bus in later BMW models. In later BMW models the I-bus connection is used for radio control via multifunction steering wheel buttons and car phone integration. This was never available for the E31 and hence the radio harness is not connected to the I-bus.
    (*2) Pin 17 is always unused. It may have been reserved for future functionality but that never materialized and BMW later changed to a different connector.
    Cable to the CD changer in the trunk / luggage compartment.
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Thanks to you both. I got it all except #10 GAL speed signal. Out of curiosity, what is that?
    Nov 2007
    Belgium
    Made in Germany
    The speed signal is used for speed-dependent volume control (GAL). The faster you drive the louder the head unit will go to compensate for the road/wind noise.
    Some head units with navigation (aftermarket for the E31 like the Becker Indianapolis) also use the signal for (linear) position tracking when no GPS reception is available (ie tunnel).
  1. FS the e30 radio wire harness
    By Jenna87 in forum 1983 - 1991 (E30)
    Last Post: 11-21-2005, 05:32 PM
  2. stereo harness. difference for HK ?
    By e36Silvr328i in forum 1991 - 1999 (E36)
    Last Post: 07-01-2005, 02:41 PM
  3. OE radio connector question
    By iammemares in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-03-2005, 09:18 PM
  4. e36 hu "harness" differences
    By buckwheat in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-22-2004, 11:43 PM
  5. Pic request..euro connector/harness for e36 euro ellipsoids
    By RJ 325is in forum 1991 - 1999 (E36)
    Last Post: 06-17-2003, 09:57 PM
