Results 1 to 9 of 9
Thread: E23 Fan clutch removal advice
    Nov 2018
    New York City
    1984 BMW 733i
    Hi Bimmerforums,
    Happy Thanksgiving to all. I'm a new E23 owner (1984 733i) and new to the forum. I looked around for how to fix this and couldn't find anything.
    The car's in great shape but I need to replace the radiator fan. It makes a horrible noise and wiggles when you grab it.
    I got the new fan and the clutch wrench but still can't get at the nut. Other examples of the M30B32 I've seen have the nut between the fan and the clutch (like this http://img.photobucket.com/albums/v4...MW/E32fan2.jpg), but mine appears to be up front. There's very little clearance between that and the radiator to get the wrench inside.
    A friend and veteran BMW guy says I should remove the radiator. I can, but as it works fine I'd rather not mess with it for now. Do you have to remove the radiator to get at the fan, or am I doing something wrong here? Any advice appreciated, thanks in advance.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    I bought the cheap two piece fan clutch wrench set on ebay. works good, was around $20
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Glad my picture helps. That was my Ljet, 12/82 if I recall.
    Yep, buy the two piece set. Makes life easier when doing Motronic style distributor caps too. Consider a water pump and coolant flush while in there. FOR SURE do the 130mm water pump pulley swap and buy a 13x1040 belt. Check alternator bushings and ground strap if using the 80A unit still.
    If you have a front mounted fan clutch, you really should consider converting it to the later style. Servicing it is much easier. B35 clutch and B35 fan on the two row radiator work awesome.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Hamburg, NY USA
    e23, e32, e34, e39
    If you still have the 13mm bolt in front, you can remove the rubber spacers on the radiator and push it a tiny bit forward. A ratchet box end wrench works great. You will still grind your knuckles on the radiator fins though. You would have had to to have purchased the correct clutch though.
    If you bought the 32mm nut clutch (like pictured), you will have to change the water pump to match it.
    Are you sure the water pump isn't causing the wobble?
    It's been quite a few years since I've serviced mine (85 735i), so I may be forgetting some details.
    Quadratechtown, PA
    5, 7, 4x4
    Quote Originally Posted by m735is View Post
    Not if you throw a towel over the radiator while you work. Recommend removing it before driving the car.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    AH YES. I have forgotten a water pump can do the same thing, that happened on the 05/85 POS I had for a parts car. Shaft had snapped from the impeller somehow.
    Great point.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Nov 2018
    New York City
    1984 BMW 733i
    Thanks for the advice everyone. Turns out it had a wrong-sized fan clutch and water pump flange. No wonder it didn't look like any of the photos or guides I found online.
    Addressing this now, car should be good to go after that. Can't wait to drive it more, it's a beast otherwise.
    Aug 2008
    chicago
    98 M3 sedan
    Quote Originally Posted by Hit Man X View Post
    Hitman x I am thinking of replacing my water pump on the L7. You mentioned upgrading the pulley. What is the advantage here ? What are thoughts on impeller material ? Seems some are metal some plastic some composite.
    Jun 2010
    TX
    1983/84/85 745i
    The L7 should have a 130mm already but it has more coolant flow at low speeds, fan spins faster, better AC at low speeds, and less propensity for lower rad hose to expand into the 144mm early one.
    I think the 10:1 car has a Graf pump now. I wanted a metal impeller.
    Ideal time for coolant flush and to clean AC condenser. Verify has 'A' thermo housing. This apparently provides better coolant flow into the head.
  1. fan clutch removal with FI cars
    By PDX///M in forum Forced Induction
    Last Post: 06-18-2002, 05:07 PM
  2. Link for fan+fan clutch removal procedure??
    By NicolasW in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-07-2002, 03:55 PM
  3. Fan clutch removal on 325/328?
    By GreenMachine in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2002, 04:14 PM
  4. Fan Clutch Removal????
    By Avus95 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-20-2002, 09:02 AM
  5. Fan Clutch removal
    By pescadito in forum 1991 - 1999 (E36)
    Last Post: 09-28-2001, 08:55 PM
