Results 1 to 7 of 7
Thread: Shogun or Anyone Else is this ZF 4HP 24 Trans Going to Work
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Shogun Any problems with using this potential transmission???
    My Car is a 1991 BMW 850i with a build date of 12/90 and a dead Trans is a ZF 4HP 24 Marked 1043 30 45 Sorry for the bad cell phone picture with the trans still in it.
    Potential Donor is a 1991 BMW 850i with a build date 10/90 Marked 1043 30 041
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    1043 030 041 used on 850 from 01/1990 - 07/1992 gear code GY, NT: 2400 - 1218674; AT: 2400 - 1218675
    1043 030 045 used on 850 from 04 /1990 - 01 /1993, gear code HQ, NT: 2400 - 1218796; AT: 2400 - 1218797
    see page 387 http://avtgr.ru/data/pdf/Technical_data_2015-07-31.pdf
    and it says "Ersatzmöglichkeit durch..." = replaceable possible by.... under E31 850 M70B50
    If I understand it right, it is possible. Maybe someone else can comment on this to make sure.
    Oldham UK
    '00 330i Sprt '92 525i
    If you search the data file for 1056 000 073, it shows 1056 000 075 in the replacement column. I know that to be correct because I have exchanged them. But in the case of the 1043 030 041, that column is blank. Realoem usually says if the transmission is replaceable retrospectively but that information is missing in this case. It is also too old to be listed in the ZF Reman. Transmissions brochure. While there is the slightest doubt, it may be best to contact ZF and ask them.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Went to Real OEM with both SN
    Only Difference I see is that gear ratio for the potential donor is a 3:15 versus what mine should have of a 3:64. Because of the different PN the Internal Gear Ratios of the transmissions I assume are different?
    Any idea how different?
    Donor CB03304 1043 030 041 used on 850 from 01/1990 - 07/1992 gear code GY, Rear Gear Ratio of 3.15 PN 24001218675
    Mine CB73041 1043 030 045 used on 850 from 04 /1990 - 01 /1993, gear code HQ, Rear Gear Ratio of 3.64 PN 24001218797
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No, the gear ratio's are exactly the same in all 4HP24's......
    My BMW Repair YouTube Channel
    Oldham UK
    Different diff, TC and TCM. OK, faint heart never won fair maiden. But that would be enough to make me think twice
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Tcm
    TCM may be availalble Trans came out of a car that had a six speed conversion. I will ask
    Quote Originally Posted by whiskychaser View Post
  1. ZF 4HP~24 question: wiring.
    By gt12 in forum 1988 - 1994 (E32)
    Last Post: 09-03-2014, 05:52 PM
  2. Anyone Else Skip Gears on Their Manual Trans??
    By CountryBMW in forum 1991 - 1999 (E36)
    Last Post: 11-15-2013, 10:48 AM
  3. Replies: 1
    Last Post: 12-14-2011, 06:48 PM
  4. 750i & 850 ZF 4HP-24 Transmission
    By Mark Francis in forum BMW Parts For Sale
    Last Post: 11-18-2002, 09:50 AM
  5. Anyone else having trouble connecting?
    By MarkM5 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-14-2001, 11:44 PM
