Results 1 to 9 of 9
Thread: TPMS Sensor Compatibility and Programming
    Jan 2012
    Grosse Pointe, MI
    2002 BMW 330 CI Vert
    Looking for an OEM part number or quality aftermarket product that will work with my factory TPMS system. Are there any options that do not need to be programmed after install?
    My current system is working fine, but I recently purchased a new set of wheels and winter tires and plan to have them mounted and installed next week.
    Car is a 2014, 328d X-drive
    Jul 2004
    Houston, TX
    36 Cylinders
    BMW Part number 36106890964
    433MHz system.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2016
    Ca
    2001 525it
    The German brand huf we have had good luck with, the ones at the tire stores we have not had good luck with.
    Jul 2004
    Houston, TX
    36 Cylinders
    Or from the original manufacturer:
    HUF RDE017V21
    Ah beat me to it a little.
    -Abel
    Jan 2012
    Grosse Pointe, MI
    HUF RDE017V21
    Thanks Gang,
    Is Amazon a good place to order is there somewhere better/cheaper?
    https://www.amazon.com/HUF-North-Ame.../dp/B010FXGAHI
    Also, do these need to be programmed by the dealer, or if the system is already operating properly with factory tires/wheels, and I add these sensors to a different set of factory (winter) tires and wheels, will they just be plug and play without any programming?
    Jan 2012
    Grosse Pointe, MI
    HUF RDE017V21
    I'm not saying that Amazon is bible, but their vehicle compatibility says that they are not compatible with a 2014 328D Xdrive. Is there another part number to the one posted below, or is Amazon clueless?
    I am, however, optimistic that they say that they do not need dealer programming.
    Bellevue, WA
    335d, 328xd (had 330xi)
    tirerack is usually $40-$45. huf and beru are both oem
    Dec 2018
    Raleigh NC
    F30 335i, E90 335d
    36106856209KT on ECS work ok on my 2015 F30 RWD. I just have to reset via idrive when I swap wheels.
    Jan 2012
    Grosse Pointe, MI
    Quote Originally Posted by floydr View Post
    Do you have a link for the page/part number. It didn't come up on an internet search.
    https://www.tpms.com/Huf_RDE017_p/h0017.htm says the following:
    "Check with dealer using VIN number as F30 chassis used both Huf and VDO brand sensors, THEY ARE NOT INTERCHANGEABLE!"
    It was my understanding that both are 433MHZ systems, and they are (somewhat) interchangeable, as long as you go into the idrive and reset it when you swap wheels.
    Amazon claims that the HUF RDE017V21 is not compatible and instead directs the Buyer to purchase this product: https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
    But the linked item is $5, and looks like a stem, not a sensor, despite claiming that it is a 433MHZ sensor. Anyone have any clarification to offer?
  1. TPMS / TMPS 2015 F30 340i sensor compatibility
    By Diamond Dawg in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-15-2016, 06:56 PM
  2. Do I Need TPMS Sensors for Winter Wheels or No?
    By DTownBMW in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-31-2007, 08:57 AM
  3. TPM sensor light came on need help
    By edwincamacho in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-01-2007, 06:26 PM
  4. What TPMS sensors are compatable with BMW's direct TPMS?
    By fun2drive in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-22-2007, 12:46 PM
  5. o2 sensor compatibility...
    By sweetjumper32 in forum 1991 - 1999 (E36)
    Last Post: 07-31-2006, 09:28 PM
