Results 1 to 22 of 22
Thread: Abnormal suspension knocking noise on E36 coupe
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    My 1998 E36 318is coupe has been making an unusual noise for a while now and I have not been able to work out what it is.
    I've added a video where you can hopefully hear the sound. It is that quiet knocking type sound that you can hear through most of the video.
    It doesn't make the sound all the time, maybe about 60% of the time. It seems more noticeable at higher speeds, and seems to happen at the same place on my daily commute.
    It does not seem affected by going over bumps. It does not seem to vary with road speed. It does not seem to be affected by engine speed as if I stop accelerating or put clutch in it does not change. It is not affected if I brake or use the handbrake.
    However, it seems to never happen if I am turning left.
    I can't work out which end of the car it is coming from.
    I had a look under the car (eg. rear shock mounts, anti roll bar bushes and mounts) but can't see anything obvious.
    Any ideas on what the sound could be or how to diagnose?
    (These parts have been changed in the last year or so: front control arms/bushes, inner and outer tie rod ends, rear shock mounts, RTAB, rear wheel bearings)
    Now: 1998 E36 318is coupe (supercharged) Past: 1997 E36 318is sedan; 1991 E36 325i sedan; 1994 E36 318is; 1990 E30 318is; 1995 E36 M3; 1990 E30 318is
    My BMW 3 Series Blog | DASC Owners Group on Facebook | Car Magazine Collector | Auto Books and Manuals | 1984 Australian Cannonball Cup
    Oct 2003
    Seattle
    99 M3
    If it is rhythmic goes straight or turning right, it is most likely left front wheel bearing, but don’t rule out left rear wheel bearing
    Jun 2010
    NY
    1997 328i
    I would say wheel bearing too. jack up the tire and grab it at 12 and 6, push/pull for play. Front wheel bearings are easy to do.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Forgot to add that I also replaced rear wheel bearings in the last year or so.
    When jacked up and I spin any wheel I don't feel or hear any wheel bearing noise or feel any play.
    Would wheel bearings be intermittent? Wouldn't the noise change with wheel speed (it isn't)?
    It's not very rhythmic, seems a bit random.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    I jacked the car up again and had a better look at each corner.
    I can't feel any movement when rocking each wheel.
    The rear sway bar links show a little cracking in the rubber but I can't see any movement in the links or the bushes when moving with a pry bar.
    The front sway bar links show some deformation of the rubber bushes. See photo. This isn't normal, is it?
    Rear link:
    Front links:
    Front bush:
    Feb 2010
    Memphis Tn
    2006 330ic, 2 e36 before
    Does the sound change with wet or damp pavement? Vs dry? I am chasing a popcorn sound in the right rear on mine. Again no speed relation. I also have new wheel bearings. I am going to follow this thread and wish you luck. Oh mine is mostly in the wet only.
    1998 328ic
    Apr 2014
    UK
    1995 BMW 328
    Change the front lower ARB links, they are at least past their best and can knock against the bracket
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by E36328Coupe View Post
    Disconnect one side completely and does the noise go away?
    Jun 2010
    NY
    1997 328i
    In the video it's not a tapping sound like he describes, it's a Wa Wa Wa Wa sound.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Quote Originally Posted by mike318 View Post
    I haven't noticed but it hasn't rained much here for a while. I will try an pay attention next time it does.
    I'm going to try the sway bar links, even though it's not making any different noise when going over bumps.
    I will report back here with any changes after replacing the links.
    Quote Originally Posted by Eric93se View Post
    Not sure that the video captured the sound well but I would describe it as a tapping/knocking/rattling type noise.
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by bluptgm3 View Post
    They're had it, fix them. Have found the pins are sensitive to tightness and shift in the U shapes, usually dropping off a curb and click and nothing to be found levering. A complete removal may narrow it. Best move would be later style but probably needs strut and link swap etc.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    It rained today so I was able to check and the answer is no - no difference in the noise from dry to wet roads.
    My sway bar links have arrived so I will be fitting those when I can find some time.
    Wisconsin
    98 328IS 03 325xi
    Take a look at the front swaybar mount, I had to replace one for a friend. Somehow it got crushed. Cut it out and welded a new one in. I'm not a very good welder as uh ou can see.
    Gave away my BMWs, driving a VW and an Audi now.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Ive also had to replace a swaybar mount. Mine rusted and then ripped apart. You'll get a much better weld if you prep the metal first. Grind all the paint off where the seam will be, and wipe it clean with isopropyl alcohol first.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    I finally changed the front sway bar links today but I still have the same noise.
    The new links did make a big difference to how the the car feels though. So well worth replacing these if they look worn.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    I still have this problem and it is getting worse.
    There is a bit of a rumbing noise noticable most of the time, particular the faster I go.
    There is this popping noise (that you can here in the video in the first post) that happens on and off but most of the time. It might vary based on road surface but hard to say. This goes away around left hand corners.
    Around long left hand corners at highway speeds a rumbling noise builds up.
    I checked my records and I see that the rear wheel bearings were actually replaced back in 2014 and 75,000 km ago (46,000 miles), so are older than I thought. I'm not sure what brand was fitted and they may not be good quality.
    I'm beginning to think that it may be the rear wheel bearings again. Are there any definitive tests? I can't feel any movement or rumbling with the car on a jack.
    Oct 2003
    Seattle
    99 M3
    Cupped tires?
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Cupped tires.
    Thanks for the suggestion... I couldn't see anything unusual with the rear tyre treads, so I swapped both rear wheels/tyres with spares and took it for a drive and the noise was still there (although it changed a little).
    I wasn't previously sure it was the rears but when I drive with the rear seats folded down it is much noisier so am pretty confident it is the rear now.
    Jan 2015
    The Netherlands
    E36 323i Schwarz 2 , E3
    is there nothing in your spare wheel well vibrating or rattling, , not the stock jack or something ?
    is your exhaust also properly mounted, not swaying from side to side or resonating ?
    rear shocks & mounts all in good condition ?, possibly no rubber pads on your springs ?
    just throwing some ideas out there
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Quote Originally Posted by SimonJD View Post
    Some good advice, thanks. I have been a bit fixated on thinking this is a suspension issue but I could be wrong. I will make a more thorough check of other things.
    I did replace rear shock mounts not too long ago when trying to fix this issue. Also fitted the rear springs myself so I know they have the rubber pads and I did check that they were seated okay last time I was investigating this problem.
    Apr 2002
    Sydney, Australia
    1998 318is DASC
    Conclusion to the problem: replaced one rear wheel hub and bearing. Bearing was okay but the hub was a bit bent. This probably happened when the wheel bearing was previously replaced as the mechanic had a lot of trouble getting it out last time and probably damaged it.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Nov. 2018 to Jun 2020, one and a half years. You get bonus points for persistence.
  1. E36 M3 Coupe knocking noise in the rear
    By Bushytails in forum 1991 - 1999 (E36)
    Last Post: 02-16-2017, 07:31 AM
  2. Suspension Knocking Noise
    By gjmascoli in forum 1988 - 1996 (E34)
    Last Post: 05-14-2011, 09:54 PM
  3. Suspension "knocking noise in cabin"
    By Jaydee854 in forum 1991 - 1999 (E36)
    Last Post: 10-11-2007, 05:57 PM
  4. 2001 z3 3.0 suspension on e36 coupe?
    By 3two3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-20-2006, 04:26 PM
  5. Update: Ticking/knocking noise on E36 M3
    By ToneCapone in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-24-2002, 06:29 PM
