Any help is appreciated here. My wife took the car to the supermarket and called me saying the trunk won’t open. The key won’t turn and the lock is stuck in the side to side position. I here the actuator working when locking and unlocking from either door.
I looked the the problem up and only found a YouTube video showing a guy drilling hole into the trunk.
The button goes goes in and out with no issues, but won’t turn.
Its a 2000 2.3 with the updated rear end if that makes a difference.
It could be a long shot, but have you tried lock oil?
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
Update: I took the car to work and had a chance to play with the lock. I put some white lithium grease on the key and put it in the lock. I was just real gentle with it, sliding the key in and out and also gently moving it from side to side. It seemed to do the trick. I was able to get the lock to turn again.
Is lithium grease good good or bad for the lock? It was all I had on hand.
