Results 1 to 4 of 4
Thread: Locked out of my trunk
    Far Hills,NJ
    '00 Z3 2.3 Roady, '08 M5
    Any help is appreciated here. My wife took the car to the supermarket and called me saying the trunk won’t open. The key won’t turn and the lock is stuck in the side to side position. I here the actuator working when locking and unlocking from either door.
    I looked the the problem up and only found a YouTube video showing a guy drilling hole into the trunk.
    The button goes goes in and out with no issues, but won’t turn.
    Its a 2000 2.3 with the updated rear end if that makes a difference.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    It could be a long shot, but have you tried lock oil?
    Far Hills,NJ
    Update: I took the car to work and had a chance to play with the lock. I put some white lithium grease on the key and put it in the lock. I was just real gentle with it, sliding the key in and out and also gently moving it from side to side. It seemed to do the trick. I was able to get the lock to turn again.
    Is lithium grease good good or bad for the lock? It was all I had on hand.
    Denver, Colorado
    Quote Originally Posted by dimm6 View Post
    I would expect that, over time, it would tend to gum up the lock. I would get some lock oil (not graphite) and work it in. It should thin out the lithium grease and you should be OK after that.
  1. Do your locks, unlock from the trunk?
    By kaineb in forum 1991 - 1999 (E36)
    Last Post: 08-08-2009, 01:48 AM
  2. I am locked out of the trunk
    By sharpie in forum 1991 - 1999 (E36)
    Last Post: 12-29-2008, 11:31 PM
  3. locked main keys in trunk:( now i can open it with spare:(((
    By importdude in forum 1999 - 2006 (E46)
    Last Post: 05-03-2008, 10:50 PM
  4. Emergency Help: Locked out of E39 Trunk!
    By mjdh530i in forum 1996 - 2003 (E39)
    Last Post: 01-26-2008, 05:57 PM
  5. lock stuck on e36 trunk
    By shane318 in forum 1991 - 1999 (E36)
    Last Post: 07-22-2007, 03:14 AM
