Results 1 to 3 of 3
Thread: N62 (e60) MAP Thermostat Control
    Jan 2013
    Minnesota
    2008 550ia Sport
    Hi All,
    Bit of a long shot here, but I was wondering if there is a coding method to sooner engage the DME control of the thermostat's heating element. I'm pretty happy with the car as a whole since it hasn't had many problems in my short amount of ownership. However, I do not like the amount of heat that builds up due to the 105c thermostat. Solutions are to change the thermostat element to one that is cooler, but that is another failure point. I know on M62 engines, some had a similar hybrid thermostat that also had a heater element built in to the point one member I think on bimmerforums created a small chipset to modulate the pwm by tapping into various DME measurement points in the wiring harness. I don't have a desire for playing with the electronics in this car, hence the DME control thought. Any information would be great!
    Thanks!
    Feb 2020
    Warszawa
    2007 BMW 740i
    Jul 2004
    Knoxville TN
    2009 550I Sport Package
    Performance Thermostat - 90C
    Includes housing and sealing o-ring
    Low-temp thermostat reduces stresses on engine components and improves performance
    Mfg Part #
    11537586885-90C
    ECS Part #
    ES#2807159
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... -- WOW-- What a Ride!" [author unknown]
  1. P1622 Map Cooling Thermostat Control Circuit Electrical
    By cdk348 in forum 1995 - 2001 (E38)
    Last Post: 09-11-2013, 10:01 PM
  2. Map sensor controlled thermostat controll / circuit
    By heinz in forum 1995 - 2001 (E38)
    Last Post: 03-08-2009, 07:19 PM
  3. Map sensor controlled thermostat controll / circuit
    Last Post: 03-07-2009, 11:52 PM
  4. Trouble Code: Electric Thermostat Control - Final Stage?
    By Hotswimmer in forum 1988 - 1996 (E34)
    Last Post: 06-30-2006, 04:14 PM
  5. E60 530i Radio Control on/off
    By biffrocket in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-13-2006, 10:33 PM
