Hi All,
Just hopefully about to pick up a 2000 740 with the check engine light on. I wont be picking it up without an OBD 2 diagnostics on the day.
https://www.youtube.com/watch?v=IymL3nD4TUE&t=14s
The owner claims he doesn't know the issue but did record this video and writes
'At 1:30 it goes to it's normal idle when it's warmed up slightly. At 2:00 I rev it to show how the revs drop slightly if it's revved gently (as it only does it when it's revved really gently).'
Having looked around people suggest a number of sensors, but has anyone else had a similar issue with a solution and rough cost?
Besides that I am looking at buying advice pages but any tips for the day would be amazing and cant wait to hopefully pick one up.
Thanks,
Tom.
My bet is that the plastic tube from the secondary air pump is broke and leaking. Does it sound like there is an exhaust leak at idle also? Then it goes away after 2 min when the idle returns to normal.
You could buy a Peale Tool and read the codes in BMW speak.
https://www.peakeresearch.com/appguide.htm
I would get a laptop loaded with INPA and a 20pin cable. The idle should be much lower and the engine revving could be many things. A simple test would be to unplug the MAF and run the car. If the symptoms change that's $400 for a MAF. Next would be a vacuum leak from the manifold gaskets. Not expensive but fairly involved DYI.
Good luck
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
