Results 1 to 6 of 6
Thread: Peake Research Tool
    May 2018
    Philadelphia
    1994 325i
    Peake Research Tool
    Has anyone ever used the Peake Research Scan Tool for their E39? If so, how do you like it? I have one for my E36 and I really like it. So I was thinking about buying the adapter so that I can use it on my 2002 M5. Thoughts?
    TX
    E36 P38
    Rather than buy an adapter, I bought a male ended OBD-2 cable with loose wire ends off amazon for about $8 and then cut the female round 20 pin connecter out of a car at the local pick a part. A little bit of soldering and I have an adapter for less than $15 that works great. The peake tool itself works well on the E39, I was able to scan codes and reset service and check lights. So for minimal expense you get a lot more diagnosing and clearing ability than a plain OBD2 code reader. DIYs are plentiful for building a cable also.
    San Jose, CA
    1997 BMW 540i 6 speed
    Build or buy: that's the conundrum. Time is money. He may not wish to run around looking for parts and then fabricating a kludge.
    May 2018
    Philadelphia
    1994 325i
    Quote Originally Posted by smickler View Post
    Any chance you have a link to the cable that you purchased and a diagram for the wires that were soldiered together?
    I don’t mind a little bit of work as long as it works and I can save money to put into the car.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    TX
    E36 P38
    Ok so I was a dollar off. I figured it was easier to cut a female round pin out of a junkyard car than to try buying the part from the dealer then have to pin and wire it. I used the links Shogun posted to build a cable. Here’s the link to the OBD plug I bought from amazon.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Obviously this will require a multimeter to find the specific wires and pins you want to join, and a solder gun. I also did this because I could prime the OBD plug and build a cable faster than I could get one delivered to my doorstep.
  1. Opinions: Peake Research Tool
    By Hank in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-18-2002, 04:05 PM
  2. FS: Peake Research Tool R5B
    By JLee in forum BMW Parts For Sale
    Last Post: 11-22-2002, 10:52 PM
  3. Anyone got a Peake Research tool?
    By Low Level in forum 1991 - 1999 (E36)
    Last Post: 11-04-2002, 01:41 PM
  4. Peake research tool... anybody have one die?
    By Cheuk in Seoul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-29-2002, 04:36 AM
  5. Peake Research Tool
    By 97Bimmer in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2001, 04:09 PM
