https://youtu.be/Y7DAcEUx-M8
We are excited and proud to introduce our own Extreme Power House Carbon Fiber Tips for your BMW F80/F82/F83 M3/M4. With our Carbon Fiber finish, the sight of your exhaust will never look better!
Our tips have a simple install that will take you about 10 minutes to complete. In order to successfully install, you will need to push out the stock tips. Since XPH tips use the stock connector, all you have to do is slip them on resulting in a straightforward install. Our tips will not use any clamps or screws. There will also be no wielding required!
Once installed, you will notice that the tips do not excessively stick out. Instead, they will be in the same place as your stock tips. However, will look much better!
Features:
- High quality gloss carbon finish
- no cutting, wielding or clamps needed
- plug and play install (uses stock clip)
- rolled tips for a clean look hiding the exhaust pipe
- 90mm outlet size
This Item Will Only Fit The F80/F82/F83 M3/M4 BMW.
Straight forward install, no wielding, cutting, clamps or screws.
https://youtu.be/BMOEOD7Ekuk
