Good morning,
So here is the short story leading up to this plan...
Jan 2018 - Bought my wife a good little DD that she absolutely loves and will not part with ... #win (1996 328i sedan 5-speed)
Refurb and refresh thread -----> https://www.bimmerforums.com/forum/s...(328i-5-speed)
-She has driven the ever-living day lights out of the car this last year, besides typical maintenance items it has been a dream.
11/18/2018 - Now... HG is on its way out, pressurizing the coolant with a little pressurizing in the oil. No oil-water mixture, no white smoke.... but it's on its way out.
To me it seems foolish to put a HG on a 260k mile m52b28...
**although if this were the last option I would still do it because motor runs absolutely flawless... no ticks, uses about 1/2qt oil every 3k miles, pulls strong**
So.... here I am looking for low mileage M52B28 to swap into car and I literally can't find one that I can get to me in the next 10 days. I want to take advantage of my Thanksgiving break and knock this out so I need a motor ASAP.
Well I come across two S52's, lower mileage and I start throwing around the idea of just doing an S52 swap.
I have read a couple threads that says essentially everything is bolt-on except power steering pump, but that with a little fab that can be mended as well. So I believe I am about to go down this path this week.
Please give me criticisms, advise, pointers, opinions!!! ALL ARE WELCOME
-currently working on logistics picking up used S52-
They call me Spaz
-1990 535i/5 with some stuff ----->M30 Turbo Build
-1996 328i sedan (S-52'd) 5-speed ----------> Refurbish Project (Wife's new DD) ---> (S52-swap)
Sourced a 150k mile S52. Going to pick up after work today, tear down starts tonight. Wish me luck!
Plans...
-Front main/rear main
-Oil nut + oil pan gasket
-New vacuum lines
-Valve cover gasket
-T-stat housing gasket (I already have metal one)
-Water pump gasket ( I already have new one and smaller billet ECS pulley)
-Oil filter housing gasket
-Engine Mounts
-Spark plugs
I will be using my 5-speed that is already in car because I just did input/output trans seals and Redline when I put clutch in car last spring. I will be using this same practically new clutch and single mass flywheel.
Any thing that I am missing?
They call me Spaz
The only thing I can think of is the DME is different, but don't quote me I think you can flash yours to a ms41.2
Yes, shop I am getting motor from is letting me use the ECU from car (5 speed also) until I can get car to them so that they can re flash. If you have an details on this I am all ears.
I have heard you can drive with M52B28 ecu, others say no... Shop owner mentioned the S52 ECU should plug right up and be operable.
They call me Spaz
Not unless it’s been EWS deleted.
It will plug up but it won't be operable. You will need to sync the EWS or have it deleted. I did an S52 swap on my 328i and it was pretty straightforward. My S52 came with all the accessories though so I didn't have to muck about with the power steering pump.
They call me Spaz
The “M” PS lines are a bit different than the non-“M” lines, due to differences @ the pump.
Order the “M” lines and you are good, as the PS Rack is the same. The M PS pump lines require a banjo fitting on the supply side from the reservoir and pump to rack line is different as the pump output bung is in a different location as I recall.
Look at the part number differences in www.realoem.com and order the part numbers that are not common between the two.
Use www.bmwpnpc.com to find the cheapest OE source. I would steer clear of low cost brands such as URO.
Febi is part of Bilstein Group, I’d say that Rein is good, and there are others.
Parts from FCP European come with lifetime warranty.
I was under the impression that there were engine harness differences between OBDII 328 and OBDII M3, no? EWS will be an issue with different ECU than that which was coded to the car.
I would be tempted to run the 328 ECU, ‘chipped’ for Shrick/S52 cams and M/S50 intake manifold.
Your existing ZF 5-speed is the same transmission the came in the S50/S52 cars, with minor differences. M3 got ATF, 328 got MTL.
Do the transmission shift detent pins while transmission is out. The later transmission can have this issue mid-life.
“The ZF S5-31 transmission is referred to as "S5D 310Z" by BMW. The transmissions made from September 1995, were made with a reinforced design and are named "S5D 320Z", and is rated for 320 Nm.”
Most OBDII if not all S52 M3s and 328s came with later model.
…and you might consider replacing the clutch/pressure plate while you are at it.
No engine harness differences. I run an automatic 328i harness on my manual M3 (auto sub harness is coiled up and not connected). A 328i ECU can be flashed to M3 specs but it may be cheaper to delete EWS on the M3 ECU.
The software is only $25 and you need a cable. This link has basically all the starter info and the links to get the tables and roms. I've been planning on getting the software to make some changes.
https://sites.google.com/site/openms...s41-flash-tool
DME/ECU
I am shipping the stock m52 ECU to Kassel Performance. Talked with guy yesterday, super helpful. Doing S52 tune and EWS delete, secondary pump delete...etc
https://www.kasselperformance.com/
Any other programming you can think of, maybe catalytic converter delete?
POWER STEERING
I’m going I go check condition of ps lines on the donor m3 car and see if I can get them. This is probably best option for getting this done this week.
The donor giving up its heart to live again in another e36
They call me Spaz
My buddy ran a Kassel tune right up until he totaled the car. The tune was super good. His manual swapped 2.8 liter with a 4.10 rear end was able to keep pace With my tuned s52 on a 3.23 lsd
Use the s52 power steering lines. The m52 lines wont fit the s52 pump.
Some progress pics, been super busy but I’ll post detailed pics after it’s in and running.
I don’t know what order these attached as I’m posting from my phone...but I ended up buying transmission as well as motor and also did a lot more “preventative maintenance” than I had originally planned...
m3 5-speed got the following
- new input shaft seal
- new output shaft seal
- new selector rod seal
- Redline fluid
(I didn’t do detent pins I couldn’t get kit here in time)
S52 got the following treatment
- All coolant and vacuum lines replaced (every single one) World-pac is awesome
- Oil nut torque’d and tacked
- Oil pan gasket
- front main
- rear main and rear main housing
- Oil dipstick o-ring seal
- crank case vent kit
- cleaned ICV with new hoses
- new coils and plugs
- valve cover gasket and bolt gasket washers
-cleaned and painted
F8B4571A-5D88-4AB8-89A9-2744C50C7CE0.jpg64F8F8B3-5509-4BF1-9FF8-98FED941DD2E.jpgDC03CC11-8545-4CFF-8EF5-EF0141D914ED.jpg2B7E54F1-FDA7-416A-ACF8-9A0ECA97E2EE.jpgA2F7181E-4961-4D49-B84E-A39A78AE8B4E.jpg
They call me Spaz
Looking good. What did you coat those headers with?
Long story short... the swap went well. Had a couple late nights as I spent a lot of time doing preventative maint. on S52...
Car started on first crank! It is a completely different car now, S52 pulls strong to redline (pegs 328i tach out haha), now it needs brakes and suspension!
Huge thanks to DeCoster Auto Werke for the S52 and M3 trans and also the help along the way... and Kassel Performance for the DME!
Getting S52 and M3 trans torn apart
IMG_1633
Cleaning trans and oil pan
IMG_1627
IMG_1643
Threw dab of ultra-grey at timing case-to-block joints
IMG_1645
Cleaning oil pump nut/torqueing and tacking
IMG_1640
Placed a small TIG tack with Er70s filler rod
IMG_1642
Oil Pan all buttoned up with new Oil Check tube o-ring
IMG_1660
New vacuum lines and crank case vent kit, coolant lines, also vanos oil supply line and washers...
IMG_1646
IMG_1655
IMG_1697
Swapped M52 TB with S52 TB so that I could keep traction control (wife’s DD)
M52 TB…
IMG_1702
S52 TB…
IMG_1704
I re-used the single mass fly wheel clutch kit that I had just recently installed on old M52 with a new pilot bearing for the back of the S52 crank…
*I understand that the S52(M3) clutch and the M52 (328i) clutch vary slightly as the S52 has larger diameter and pressure plate…
but I am going to get my money out of this set-up while I can, this clutch is practically new and of course it may not last as long
but we’ve had not issues yet an I have done a couple hard launches and pulls with it, the wife won’t be driving it that spirited haha*
IMG_1710
Prepped and cleaned S52
IMG_1691
Trans getting the following…
-input shaft seal
-output shaft seal
-selector rod seal
-redline fluid
-new shifter bushing and cup
IMG_1677
IMG_1680
IMG_1687
Once S52 was prepped I pulled old M52 from car, cleaned engine bay and prepped for install...
56454279322__6461FA77-10B2-40A2-87D1-8D9C5D5ECB01
IMG_1671
IMG_1676
S52 and trans mated and ready to drop in…
IMG_1711
IMG_1713
IMG_1714
56469338938__B24402CC-58F6-43E8-BCF6-616656395A6D
Accessories (set-up)
I wanted to list what I did as there was some questions regarding interchangeability between S52 and M52…
My set-up:
-M52 A/C compressor and bracket to block
( I didn’t want to break the A/C line so I gently removed from old motor prior to pulling and strapped it aside out of the way without putting too much stress on A/C lines, I did the same with the condenser on the radiator support, I also cleaned out fins really well.)
-M52 alt. ( I had recently replaced it so I reused the one from M52 motor.
-S52 Power Steering pump.
( Iiked the fact the S52 pump has a metal pulley as opposed to the M52 plastic pulley that could grenade… only thing that is different is the high pressure line from Pump to Rack, the bango fitting for the S52 is different than M52 pump, the racks are the same though.)
*Also due to the different pulley that has smaller diameter on S52 pump there is an additional idler pulley that bolts to the oil filter housing (the one with the offset orange bearing in picture, still uses the same serpentine belt as M52 though*
-M52 water pump and ECS pulley (direct swap)
IMG_1720
Getting front end buttoned back up…
IMG_1722
EWS alignment with S52 DME from donor car
IMG_1727
** I will be using original M52 DME when it returns from Kassel Performance**
-cat delete, S52 tune, secondary air pump delete
The wife capturing the final touch… so satisfying !! M-Power!!
IMG_1734
Looks like it belongs!
IMG_1750
They call me Spaz
Thanks man!
I used VHT in SP117 (Flat Aluminum)
http://www.vhtpaint.com/high-heat/vh...eproof-coating
They call me Spaz
dude im learning so much from you and how you break things down....awesome job...i may need some pointers in the near future.......plz.....have a great day boss!
-currently working on logistics picking up used S52-[/QUOTE]
