Results 1 to 17 of 17
Thread: Starter replace - Wire Harness removal needed or not?
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    So I have seen quite a few posts that indicate the wire tray ( wire harness) near the windshield should be removed to get the intake manifold off.
    I venture to guess it is just difficult to get at some of the bolts on the manifold ?
    Since there is a lot of "bitching" about starter replacement I would like to hear comment on the harness "move out of the way" or not.
    Piss me off- It is just intermittent Bendix on my starter. I have had others fail like this (on other cars) in the past.
    Several of those just needed a cleaning of the Bendix/solenoid. Since this is such a bitch i went for a new starter.
    Have the manifold gasket and i know the hoses are all good (July motor swap).
    I guess about 4 hours to do the swap.
    Tim
    This car is AWESOME !!!
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I think it’s easier with the intake off. I do not remove the wire harness tray but that would give more access to the 7th nut. You can do the job from underneath, without removing the intake, but it can end up being more work unless everything goes perfectly.
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    I think it’s easier with the intake off. I do not remove the wire harness tray but that would give mire access to the 7th nut. You can do the job from underneath, without removing the intake, but it can end up being more work unless everything goes perfectly.
    I have an automatic so underneath i think is a non starter- ( pun intended) .
    Jun 2010
    NY
    1997 328i
    Definitely unbolt it and remove the metal shield above it. I hope you have a wrench that fits the starter bolts from above.
    Jun 2005
    New England
    Quote Originally Posted by Jacksone30 View Post
    I have not worked on an auto E36 but am not sure why it would prevent doing this job from underneath if you wanted to try it. I assume the starter is in the same place and has 2 bolts and a dowel holding it into the trans.
    Apr 2015
    Tennessee
    1998 BMW 328i
    The auto transmissions in these cars are absurdly huge. Its a GM transmission and its literally 2-3 times the size of the manual getrag or ZF. Much easier to access everything from above. Remove the windshield cowl drain and the intake manifold and your wrists and fingers will thank you.
    Apr 2014
    UK
    1995 BMW 328
    No, it's never going to be on a starter without a Bendix. It is a pre-engaged type starter.
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    Quote Originally Posted by XnWarden View Post
    And I just replaced the cowl ! And them wipers are a pain in the ass since I dont have a small puller to get them off.
    Maybe I'll just torture my fingers .
    Sent from my SM-N950U using Tapatalk
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    Quote Originally Posted by E36328Coupe View Post
    Well something is intermittent on the solenoid
    Apr 2014
    UK
    1995 BMW 328
    Or connections loose, or the grease on the solenoid slug just needs cleaning as old and think and no spend at all.
    Still can't have a Bendix where non exists. fundamentally different.
    Apr 2015
    Tennessee
    1998 BMW 328i
    For what its worth I pulled a starter off of an auto car and it looked very similar to a manual starter. The auto tranny still has a flexplate so the auto starter still has a bendix to spin it.
    Apr 2014
    UK
    1995 BMW 328
    Nope. Same part numbers. Same pre-engaged. Bendix has nothing to do with drive plate. Drive plate still has a ring gear.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Thanks for correcting my misinformation
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    Put in the new starter . It is a job I never want to do again. Took me like 12 hours total, 4 of which were getting the vac lines back to where they should be since starting it gave a rough idle. The e12 I borrowed from my indy shop did the trick breaking the bolts loose .
    If I did it again it would be less than 6 hours .
    Puzzled the VAC LINE from the fuel filter - dont know where to put it. Forgot from July when I swapped in the new motor. I will keep searching.
    Jun 2010
    NY
    1997 328i
    The vacuum line at the filter goes from the fuel pressure regulator to the bottom of the manifold next to the vacuum line for the purge valve.
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    Quote Originally Posted by Eric93se View Post
    Yes. The one from the fuel filter - where does that one go ?
    I had the fuel filter one on the manifold by mistake . Made it run rough. Three lines and only two spots on the manifold.
    I would look in the Bently but I lent it out .
    Any clue ?
    Jun 2005
    New England
    As someone else posted, it goes to the fuel pressure regulator not the filter, but they are next to each other. The manifold connection is under the manifold at the plenum end, towards the firewall. If you can find a picture of a manifold that might help since it’s hard to see and might take a while to feel.
  1. Wiring harness info needed. Race application
    By Dan Lipperini J in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-01-2008, 05:59 PM
  2. M3 wiring harness help needed
    By gobuffs in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 01-29-2008, 08:09 AM
  3. replacement wiring harness
    By GordonD in forum 2002
    Last Post: 05-24-2007, 07:20 PM
  4. Replacement wiring harness
    By JohnW8 in forum 1983 - 1991 (E30)
    Last Post: 01-10-2007, 10:54 AM
  5. Replacing wire harness on the trunk lid.
    By greeky in forum 1991 - 1999 (E36)
    Last Post: 09-29-2006, 01:22 PM
