Hi there,
Just last week I purchased a BMW E46 320i 2001 for a reasonable price. It's in lovely condition a nice dark blue colour and only done 55,000 kms so I'm pretty chuffed so far.
However went out for a drive on the weekend and had all the windows down as it was a lovely afternoon, when trying to put them back up rear left refuses and makes odd noises. Pretty disappointed not like it's a new car so whatever i guess!
So I have no mechanical experience but I've done a little research and from my understanding I think it's the window regulator. I've made a little video of it so hopefully someone with experience can confirm this.....? https://youtu.be/LsaRYDOa9I8
I'd like to try and buy the part myself rather than being overcharged by a mechanic but need to make sure I'm buying the right part or parts? European car mechanics can be expensive in New Zealand, maybe I could try and fix it myself, buy a Haynes manual and give it a crack? Or not a good idea for a first time repair attempt?
Thanks in advance
Hensby
I don't need to watch the video; you have described exactly one of the most common E46 failures. Yes, you need a window regulator.
It's a very easy job, except for the part where you need to remove the vapor barrier without ripping it. This is a sheet of foam rubber/plastic which is held on by a very thick black gooey sealant. You need to use a very sharp knife or razor blade to cut the sealant, without cutting the foam. This is by far the most difficult part of the job.
You need to go to Pelican Parts or Bavarian Autosport , and go to their DIY blogs, and watch a video of this job being done. Again, it is actually very easy.
You'll want a Torx 20 screwdriver or bit, a 1/4" drive ratchet, extension, and 8mm and 10mm sockets. a big flat bladed screwdriver to remove the door panel after unscrewing it, and some masking tape to hold the window up while you change out the regulator. IF the cable is not yet broken, you might just need a pair of wirecutters to cut it.
(Oh, you'll see the name of the company on the regulator is "BROSE". That stands for "Broken Regulators Our Special Enterprise"
Chris Powell
BMWCCA 274412
BROSE! Hahaha!
I have used a hair dryer to heat up the "goo" to get the vapor barrier off, and used an knife as well. It makes it easier to put the vapor barrier back when you get done.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Appreciate the tips and information
Just a couple of questions, should I buy the regulator without the motor? It's a bit cheaper and the motor still seems to be working. Or should I just buy the whole thing with the motor included?
Also is it worth getting 2nd hand ones? New ones seem a little difficult to source locally new but I don't mind shipping from elsewhere if it's worthwhile.
Hensby
You do not need a motor, just the regulator. I highly recommend AGAINST buying a used E46 regulator. These are some of the most failure prone parts on any BMW. Buy a new one, and, as much as I dislike BROSE for this item, the OEM part is 3 times better than the Chinese aftermarket things, which will even bend during installation, because the metal is as thick as tin foil
Chris Powell
BMWCCA 274412
So I bit the bullet and bought the brand new OEM, hopefully the rest of the window regs don't die in the future - Thanks for taking the time really appreciate it. I ended up making a couple of tears on the vapor guard do you reckon a bit of duck tape over the tears will keep it good?
Hensby
Hensby, glad to know you. I'd probably recommend a @" vinyl tape over the duct tape, because it's better at repelling water. Either way, yeah, I know, it's difficult to avoid ripping that vapor barrier.
Chris
Chris Powell
BMWCCA 274412
