Results 1 to 6 of 6
Thread: PLEASE HELP - E38 Trans Buzzing
    Nov 2018
    Gilbert, AZ
    E36, E46, E38, Charger
    1996 BMW 740IL E38
    So about a week and a half ago, me and my buddy ran over a cawking gun left in the road by construction workers. We hit it going about 50mph in a 45mph zone. It tore up the transmission pan and it went into the trans failsafe program about 10 seconds later. Luckily, we were close to his house so we trucked it to his house until the fluid ran out so we turned off the car to not cause any damage. We pushed it the rest of the way back to his place (Which was not easy in a big body bimmer).
    We spent days trying to find a pan for his car but all the pans we found did not match his pan. THe part number of the pan that matches his car is 24-11-1-422-146. All the other pans we found were completely square. We thought we finally found a shop that had over 50 bmw parts cars but when we got there, we found that we werent in luck because the pan they pulled was square like all the others we found. He agreed to weld the pan back together for $100. We agreed since we had no other choice. We took it home, layed the gasket, torqued the pan to the trans at 12ft lbs and topped off the pan with ATF while the car was level to the ground. We turned on the car and it runs through all the gears on the shifter properly and theres no slipping.
    Everything is fine until you get the car going. Theres a buzzing/grinding sound whenever we accelerate and I assumed it the was filter that may be dirty. I think everyone may assume that too but my problem is, the trans fail safe program turns on EVERYTIME it hits 4th gear in Drive.
    We can live through the buzzing but I want to know if anyone might have any ideae why it might be doing this. Is the trans toast? Will the dirty filter cause the trans fail safe program to kick on whenever it hits 4th gear? Anyones word helps.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E38 forum.
    do once more a fluid check based on this https://www.europeantransmissions.co...ansService.pdf
    The filter can be a problem, maybe it also has been damaged. If the filter is cracked somewhere else, it will suck also air above the ATF level, usually it sucks the ATF from the bottom of the pan. Same is with a defective o-ring on top of the filter where it goes into the trans, if that o-ring is damaged or does not fit, air is sucked, then you hear the typical whining sound in the trans.
    Nov 2018
    Gilbert, AZ
    We came to the conclusiom that it might be the torque converter running dry or even broken. We will check thw filter though
    Jan 2005
    Japan
    ".... to his house until the fluid ran out so we turned off the car to not cause any damage."
    So you just continued to drive although the trans pan was leaking and you drove till there was no fluid at all?
    Then you may have damages to the trans clutch packs and also to the TC.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    96 740 - sounds like a 5hp30 transmission - also sounds like you killed it.
    Nov 2016
    NY
    Or - how much fluid did you add. A 5hp30 takes 13.1 liters of zf fluid - did you get a compatible fluid? If you underfilled, it could be contributing - and Shogun made a good point about the filter.
  1. e46 trans issue Programmed? Please Help Bad Trans?
    By toaser in forum 1999 - 2006 (E46)
    Last Post: 07-27-2016, 09:56 AM
  2. Replies: 15
    Last Post: 06-26-2015, 04:50 PM
  3. Not the Usual Glove Box Problem - Please Help? E38
    By Hofmeisterkink in forum 1995 - 2001 (E38)
    Last Post: 04-19-2015, 11:46 PM
  4. please help auto trans.. delay going into 2nd
    By florin007 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-26-2011, 01:15 AM
  5. Please help....automatic trans shifter
    By 1987e30e in forum 1983 - 1991 (E30)
    Last Post: 06-02-2009, 07:24 PM
