Results 1 to 3 of 3
Thread: Stability control light on??
    Jun 2018
    oakboro, nc
    2001 525i wagon
    Hey gang--01 525-I wagon driving along great then the stability control/traction warning light pops on--the triangle circled with arrow sign--what do I check? Ideas before I take it in? Thanks
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    A scanner is your only solution while everything else will be "check wiring for breakage and cracking insulation" process. The speed sensors can get old, weak causing poor readings, they get clogged with dirt from those who like to go "off roading" due to poor driving skills.
    Access to a scanner will provide codes, location of error, and will confirm your repair. Everything else will be a "try this then try that" approach.
    If you want to drive up to VA, I have four speed sensors you can play with to determine which wheel is your issue.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Nov 2012
    San Francisco, CA
    2000 540i sedan
    Try checking the brake fluid. Low fluid will turn on the light before the brake warning light comes on in my 99 540 wagon. Master cylinder is under the driver side cabin air filter box.
  1. Automatic Stability Control light stays on
    By CTJoe in forum 1991 - 1999 (E36)
    Last Post: 03-05-2016, 08:25 PM
  2. Automatic stability control light stays on.
    By CTJoe in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-02-2016, 10:19 PM
  3. Auto Stability Control light (ASC) stays on - Help
    By srq in forum 1995 - 2001 (E38)
    Last Post: 08-28-2015, 10:12 AM
  4. Stability control light and brake light are on yellow
    By jrc0210 in forum 1999 - 2006 (E46)
    Last Post: 11-05-2008, 04:21 PM
  5. My traction/stability control light does not go off...
    By abtmuda in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-18-2006, 06:25 AM
