Results 1 to 6 of 6
Thread: Vacuum line help
    Aug 2018
    NJ
    E38, b4 tdi
    Vacuum line help
    Where does this one go. I traced it with purple to show it comes from along firewall. I dont know where to plug it in. Fuel pressure regulator? Where is it?
    Aug 2018
    NJ
    E38, b4 tdi
    Also this port on airbox tube by throttle body.
    Sent from my VS501 using Tapatalk
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    if I had to guess without looking at my car that line should be under the intake and go to the port on the inlet hose.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Mar 2012
    Queensland, Australia
    1995 730iL (M60B30)
    That's the vacuum line that runs to the fuel pressure regulator (as the regulator forms part of the fuel filter on the later model M62's). You can see it here, part number 13;
    http://www.realoem.com/bmw/showparts...11&hg=13&fg=10
    You can just ghetto fix it with a dual male barbed fitting, or if you want to go OEM, get a new full line piece like this;
    https://www.ecstuning.com/b-genuine-...e/13321437692/
    Thank your lucky stars the fitting isn't snapped off on your inlet tube! That happens so often. But even if that does happen, you can just get a threaded male brass barb, drill it out a bit and put that on instead. Everything is fixable. Good luck
    Aug 2018
    NJ
    E38, b4 tdi
    Sorry guys. The previous owner or maybe mechanic had this line running along the driver side upper wheel well for some reason!! I didn't realize the long long rubber hose connecting it to the intake for some reason when taking it apart hahaha
    What a pain in the butt.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by Sobek View Post
    $50 for a tube like that...should be a felony!
  1. Vacuum Line help
    By PitchblakToxic7 in forum 1991 - 1999 (E36)
    Last Post: 05-17-2012, 08:05 AM
  2. 528 Vacuum line help
    By Bloodrunsdry in forum 1982 - 1988 (E28)
    Last Post: 07-24-2011, 07:01 PM
  3. M50 mani swap need vacuum line help
    By apocalypse01 in forum 1991 - 1999 (E36)
    Last Post: 02-09-2011, 11:35 AM
  4. M50 -> e30 Coolant and vacuum line help
    By gman3280 in forum Engine Conversions
    Last Post: 07-29-2009, 03:17 PM
  5. Vacuum line help (manifold to master brake cylinder) - no brakes!
    By bostongreen328i in forum Forced Induction
    Last Post: 08-31-2007, 11:48 PM
