Results 1 to 14 of 14
Thread: OVERHEATING! - Replaced headgasket & cooling components already -318ti w/ M52B28 Swap
    Feb 2016
    Texas
    95 M3, 95 Ti M52, 330ci
    So I got this 95 TI with a M52B28 swap (Harness is ODB2, not sure about the rest), overheating issues, seller claimed blown head gasket. Had low compression on 5&6 or is it 1&2 (Back 2 cylinders)
    1: Took it home and pulled the head, got it machined, pressure test, decked, cleaned, valves. Full workup & everything checked out.
    2: Put it back in the car, replaced thermostat, water pump, thermo housing, all cooling hoses. Replaced stock crank fan with mishimoto electric fan. I also replaced crankcase sensor since it was also bad (Not related to cooling issue but I was getting a code)
    3. Buttoned it all back up. Compression was solid across all 6 cylinders (150-160). Added coolant & new oil, bled line 3 times with heater running max and vent open. Still overheating in about 10 minutes @ 800rpm idle.
    Community, what should I try next? Am I missing something?
    Oct 2003
    Seattle
    99 M3
    Water pump.
    Feb 2016
    Texas
    Yikes! Sorry for not mentioning earlier (original post has been updated). Water pump was also replaced (Stewart)
    May 2017
    Owings, Md
    1998 328i
    Sounds like it still has air in the system but how are you reading the temp? Did you keep track of how much coolant it took and did you try cracking the bleeder when it was overheating?
    Jun 2010
    NY
    1997 328i
    Check the belt is good and the tensioner is working.
    Feb 2016
    Texas
    Quote Originally Posted by gdavid View Post
    I'm reading the coolant temp from the obd2 port (Bluetooth app). Does that make sense?
    I've poured about 2.5 quarts in. Bleeder valve is currently open when I turn the engine on. I see very small bubbles intermittently. Not sure what zero air looks like though.
    Sent from my Pixel 2 XL using Tapatalk
    Feb 2016
    Texas
    Quote Originally Posted by Eric93se View Post
    Water Pump is spinning, tensioner and belt look good.
    May 2017
    Owings, Md
    1998 328i
    Quote Originally Posted by st4t1c View Post
    Yes, I do the same thing.
    Jack the front of the car up take the upper radiator hose off at the radiator and pour coolant down the hose until it comes out of the radiator neck. Reconnect the hose and bleed it again with the front end still up.
    May 2009
    Bangkok, Thailand
    5/93 E32 730i M30
    Maybe I missed it... but is the radiator good ? Are you sure ??
    Feb 2016
    Texas
    Quote Originally Posted by tomquic View Post
    I'm definitely not sure. How can I tell?
    May 2009
    Bangkok, Thailand
    5/93 E32 730i M30
    If its original I'd say it's due for a replacement. You could try a pressure flush to start. But you have changed almost everything else.. which suggests to me the radiator...
    Apr 2015
    Tennessee
    1998 BMW 328i
    To check how bled the system is, remove the expansion tank cap. Squeeze the upper and lower radiator hoses together and watch for the stream of coolant to spray back into the tank thru the bleed port. If it's well bled, it will be a solid stream. If there's lots of air it won't be a solid stream.
    Oct 2003
    Seattle
    99 M3
    I hope you added close to 2.5 gallons, as 2.5 quarts is not enough to fill just the radiator.
    How do you know it is overheating?
    May 2017
    Mb, Canada
    1998 BMW 328ic
    I would say air in the system, followed by radiator possibly NG. When bleeding the system remember to put the heat in the car on full hot so the heater core valves are full open. I didn't find it necessary to
    raise the front of the car up to bleed the system nor did I remove any hoses it just takes some time to fill the system up if the thermostat if closed because it fills up the block through the miniscule hole in
    the thermostat. When filling up you can and should squeeze the radiator hoses to move the fluid through the system. It takes quite a while to bleed the system but eventually you should get no bubbles coming
    up through the bleeder screw. There are a lot of posts on bleeding the system as well as the usual you-tube videos.
    Don B
  1. Longevity of cooling components after initial replacement
    By pnort in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2011, 12:34 AM
  2. New to BMW's, need to replace headgasket
    By Stranger in forum 1988 - 1996 (E34)
    Last Post: 07-08-2004, 03:36 PM
  3. Replacing Headgasket
    By tonym in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-30-2004, 08:59 PM
  4. 92' 325i overheating. Thermostat?... headgasket?
    By Digitalwave in forum 1991 - 1999 (E36)
    Last Post: 06-30-2003, 11:38 AM
  5. 2.5 eta replace headgasket or look for a motor
    By Dade in forum 1983 - 1991 (E30)
    Last Post: 03-09-2003, 12:37 AM
