RM European Auto Parts
Results 1 to 15 of 15
Thread: catalytic off
    Aug 2018
    Armenia
    2001 BMW E39 530i
    catalytic off
    hi everyone. I have 2001 e39 530i with dinan stage two software. I would like to know if I will take off catalytics,service engine soon icon will turn on?
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from General BMW Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Yes, the SES light will stay on.
    Chris Powell
    BMWCCA 274412
    Aug 2018
    Armenia
    2001 BMW E39 530i
    So what do I have to do?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Put tape over the SES light. /s
    You’d have to install O2 sensor simulators. They’d fool the engine computer (DME) into thinking that the cats are working properly. O2 sensor simulators are now illegal. Why are you pulling the cats? Are they blocked?
    Aug 2018
    Armenia
    2001 BMW E39 530i
    yes they are blocked,I want to take them off.what about a new software?If I will install a new,in my country we call it uncat software,its only for cats,my Dinan software will delete?
    Jun 2002
    E39M5, E500 4WD
    Yes, you will lose your Dinan tune if you install new software. That said, if you can get a Dinan tune where you live, you can also order a pair of Magnaflow aftermarket cats; they're only $70 here, maybe someone in Yerevan can get these or something similar for you?
    https://www.summitracing.com/parts/mpe-53956
    I believe that your cats are actually an integral part of the exhaust manifolds, so you're not going to be able to easily "delete" them. If, however, you're willing to put up with the SES light being on, and use tape over it, you can unbolt the exhaust at the rear of those manifolds, and use a long screwdriver and a hammer to shatter the ceramic, and allow it to fall out.
    There you go; the right way, and the wrong way.
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    you can also have the tuner code out the rear o2 monitoring if you are intent on removing the cats....
    of course, that doesn't solve the part about actually removing the cats - since, as chris points out, i believe they are integrated with the exhaust manifolds on this engine.
    but, if you can solve that problem, you can easily put some magnaflow cats in the exhaust (simple weld in process) under the car. then, have a tuner tune out the rear o2 and you are done, and, you've still kept the environment somewhat happy!
    Jul 2004
    Houston, TX
    36 Cylinders
    Send me your file and I will fix it for you.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    E39M5, E500 4WD
    There you go, SMBO....328 Power 04 can do this. He'll retain your Dinan tune, and fix the issue you're facing. Trust him, he's the best.
    Click on his screen name above, and then send him a private message with your email address.
    Chris Powell
    BMWCCA 274412
    Mar 2003
    St. Joseph, Mo.
    agreed, 328 power 04 is the guy....super helpful and absolutely knows these systems.....
    Aug 2018
    Armenia
    2001 BMW E39 530i
    thank you very much
    Aug 2018
    Armenia
    2001 BMW E39 530i
    How can I contact with you?
    Jul 2004
    Houston, TX
    36 Cylinders
    Send a private message with your email address.
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    Email sent.
    -Abel
  1. No more Check engine light when removing catalytic converter!!
    By bmwguym3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-06-2001, 12:25 AM
  2. catalytic converter........factory warranty for 80K?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 09-05-2001, 04:04 PM
  3. Removing Catalytic Converter...Any performance gains?
    By seoulman in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 02:50 PM
  4. catalytic converter ???'s
    By 808M3 in forum 1991 - 1999 (E36)
    Last Post: 07-16-2001, 09:34 PM
  5. High flow after market catalytic converters?
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2001, 11:11 AM
