RM European Auto Parts
Results 1 to 5 of 5
Thread: New here so here goes advise appreciated
    Nov 2018
    kent
    bmw 318 ci
    Got a 318 2004 was running ok, took it for a drive Engine light came on no power, got it scanned and multiple misfire came up, got a compression check and middle two cylinders were very low 65-70 respectively.
    The car misfires badly now but doesnt overheat on the gauge.
    I was thinking of tipping some engine restore down middle 2 cylinders to bring up compression, my mechanic suggested worn pistons or chain
    Had the plugs out there are covered in black soot and not very clean coil packs are also ok, i have noticed when removing expansion cap there is pressure even if its cooled right down or even the next day
    any ideas of what to try next
    cheers
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    A compression check is just the start, you will need to have a leak-down test performed to see if it is the head gasket, leaky valve or bad rings. If it was a bad chain, it would be on all the cylinder, not just two.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Nov 2018
    kent
    bmw 318 ci
    thanks for reply, do you mean low compression on all the cylinders if the chain was bad ?
    I was toying with the idea of whacking some engine restore down the 2 low compression cylinders to bring them back up, its lumpy now and just about drives, is it true theres no water ways between the middle 2 cylinders as it doesnt overheat or show any signs of contamination in the expansion tank or on the dipstick, just a little on the filler cap but thats condensation
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Hi Darin, glad to see you again, I've missed seeing you for a while!
    John, as Darin suggests, you need to do a cylinder leak down test. You should do this with all plugs out, and see whether the pressure from cylinder 2 blows out cylinder 3, and vice-versa. It seems likely that you've blown a head gasket.
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    Thanks Chris, been working a new job and that takes a lot of my time as of late.
    OP, you could attempt to put some resto down those two cylinders, but again without proper diagnostics completed, you could be wasting time/money.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Neucast Episode #14: BMW test drives, new Saab, VW Scirocco goes into production
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-18-2008, 04:10 PM
  2. New to BWM, looking for advise
    By tobybul in forum 1988 - 1996 (E34)
    Last Post: 06-28-2007, 11:39 PM
  3. typical blown head gasket, warped head, advise appreciated
    By finnan in forum 1988 - 1996 (E34)
    Last Post: 05-15-2007, 10:20 AM
  4. My new Turbo M20 2002 goes 13.7 at 107!!
    By M20Curtis in forum Forced Induction
    Last Post: 11-20-2005, 02:33 PM
  5. New Z4 Owner - Need Some Advise from the Pros
    By kakrist in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-09-2005, 07:42 AM
