Results 1 to 13 of 13
Thread: New motor mounts!
    Texas...all of it.
    328i
    New motor mounts!
    Changed my motor mounts today. So far this has been the easiest job I've undertaken with this car. It took a frustration-free 20 minutes...and only that much because it took a little finesse to lower the engine onto the studs neatly. The mounts were a complete wreck.
    https://imgur.com/a/JH6qM5T (if you get a "forbidden" message it's this forum's software blocking the link...just click the address bar and hit enter, or copy the link and paste it to the address bar)
    Right side was torn and soft. The left side was held together with hopes and good wishes...but nothing else.
    I recently had a lot of trouble addressing a leaking power steering fitting and I think the damaged mount is the culprit. The engine was sitting quite a bit lower on the left before I changed the mount and the line, when I finally got it removed, had obviously been struck on the engine side. I think the engine would tend to lean that way, and hit the fitting, which loosened it over time. I think the engine was moving a LOT. While I was down there I inspected the exhaust...I have two sections that are fixed with clamps and they'd wiggled almost completely out.
    I think this will improve some things.
    San Jose, CA
    1997 BMW 540i 6 speed
    This is the E39 forum.
    Texas...all of it.
    328i
    Oh wow and here I am talking about aircraft carriers...
    JimLev's Avatar
    JimLev is online now Artifically Aspirated Moderator
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by edjack View Post
    He's got a '97 540.
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    Quote Originally Posted by makenzie71 View Post
    What kind of flight deck you running? Steam?
    what propulsion system is your vessel fitted with?
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
    Oct 2012
    Charlotte, NC
    2003 540it
    damn your motor mounts looked crispy
    2019 X3 M40i Glacier Silver
    -stock
    2003 540iT Titanium Silver
    -Dinan Exhaust
    2003 325i 5-speed Japanrot
    -BMW Performance Intake
    -Dinan exhaust
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Took me just a second to figure that out. Lol...
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by topaz540i View Post
    what kind of flight deck you running? Steam?
    What propulsion system is your vessel fitted with?
    lol.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    May 2017
    Houston
    03' 540i, 05' 545i
    What are some obvious signs that these will need to be replaced soon? I doubt mine are not original to the car.
    Texas...all of it.
    328i
    You can physically inspect them. They're visible. If the rubber is deteriorated, change them. They're also not very expensive so it might be worth changing them just for the sake of doing it. Mine you could see some of the rubber damaged just by looking down on them from the above.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Now those needed refreshing!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Dec 2013
    Southeastern US
    2003 BMW 540i M-Sport
    What mileage are you at?
    2003 BMW 540i M-Sport in Sterling Grey | Sold 2/2020
    Texas...all of it.
    328i
    278k
  1. Would new motor mounts make car sound louder from inside?
    By rancho5 in forum 1983 - 1991 (E30)
    Last Post: 12-11-2006, 04:32 PM
  2. Brand New Motor Mounts E36m3
    By VigilanteMotors in forum BMW Parts For Sale
    Last Post: 09-20-2005, 09:14 AM
  3. What turbo manifold doesn't require a new motor mount?
    By uoYkcuF in forum Forced Induction
    Last Post: 04-19-2005, 11:56 PM
  4. New motor mounts installed + fan delete
    By SupaBimma in forum 1992 - 1999 M3 (E36)
    Last Post: 12-13-2004, 07:16 PM
  5. new motor mounts
    By comptechgsr in forum 1992 - 1999 M3 (E36)
    Last Post: 03-30-2004, 11:28 AM
