RM European Auto Parts
Results 1 to 9 of 9
Thread: N52 extreme oil consumption
    Nov 2018
    France
    2005 BMW 523i
    Hi All,
    My 2005 e60 523i 133k km consuming 1 litre of oil every 500kms. Yes that's a lot, has been consuming first 1L every 1k km very slowly degrading since 20k km.
    Replaced CCV and connected hoses twice, head gasket, valve cover gasket, intake side valve seals no effect.
    Dry and wet compression looks OK with cheap Chinese tool, no errors thrown, exhaust pipe gets black on the outside but no visible smoke except a occasional small puff of blueish smoke on startup after few hours sitting. More than usual white steam in cold weather, goes away when hot. No external leak except few drops of oil on bottom of gearbox probably from rear crank seal, but never anything on the floor.
    There was nothing obvious when removing the head, except for two cylinders.
    Cylinders 3 and 5 have plugs covered with dry black soot and are also wet in the inside, other plugs look good but thin black layer on the bottom metal ring, thin black dry deposit on the top of pistons but might be normal.
    Unfortunately I didn't take the head to a shop when it was off as seeing the intake valves (pics) i concluded that the seals were the culprit. Exhaust valves were all covered with very thin black layer, except 3 and 5 with thicker cover, all dry, my spring compressor anyway didn't fit to replace exhaust seals.
    I still suspect an issue with either the CCV system or intake valves. I removed intake manifold 3 times, each time there is oil at the rubber seal to the engine and I would think only the valve rods would be black instead of the whole intake port if it was valve seals. Intake manifold had 1 spoon oil in it but has not been cleaned for 20k km, no obvious oil pooling inside the manifuld since last 2k km. I once run the engine with CCV hose disconnected from intake manifold and the hose was throwing out a lot of oil, which again might be normal without intake vacuum?
    Some pics below of intake ports and oil around manifold screws and seals. Any idea?
    https://ibb.co/cgL5jf
    https://ibb.co/bYrpAL
    https://ibb.co/cTP9AL
    https://ibb.co/mjYfH0
    https://ibb.co/ewNwqL
    https://ibb.co/eT5hVL
    New York
    1974 2002, 2009 128i
    What is the crankcase vacuum at hot idle?
    Black soot is likely fuel, not oil. Possibly you have leaky injectors that are washing fuel into the oil. How does the oil smell?
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    +1, check the crankcase vacuum. From O2 Pilot's epic oil consumption thread, here's how to make a manometer at home:
    https://www.bimmerforums.com/forum/s...lacement/page8
    In your pictures, I note that none of the intake passages actually look wet or oily. The oil which I see seems to all be EXTERNAL, especially on top of the head gasket. Since you've gone so far as to replace the head gasket, I understand that you've been thorough.....but are you absolutely sure you don't have an external oil leak, from the oil filter housing gasket? I replace these every week, including the heat exchanger gasket. They are HUGELY common leak spots on this engine.
    Look on the front of the engine, under the oil filter housing....then behind the housing, since you've got SO much oil at the head gasket seam. (I am not suggesting the head gasket is the culprit, just that this is where the oil collects)
    Anyway, make a manometer, fill it with colored water, drill out a spare oil fill cap (the one on the valve cover), and test your crankcase vacuum. Vacuum should be 3 to 6 inches of WATER. (Oops, sorry: 7.5 cm to 15 cm of water.)
    Chris Powell
    BMWCCA 274412
    Nov 2018
    France
    2005 BMW 523i
    Thank you both, I could and probably should check for crankcase vacuum. I have not done it yet because suction at the oil cap wasn't very high. There is a bit of vacuum but very easy to open the cap.
    I did start by replacing oil cooler and filter housing gaskets as they were indeed leaking a bit, no help. I should be very easy to notice an external leak of this severity.
    The oil you see on the head gasket are drops of oil rolling down from each of the intake ports when I removed the manifold. The ports and the manifold tubes are only slightly moist. If I disconnect the hose from the CCV to the manifold, that one is very oily in the inside. I didn't find a way to look if any oil is pooling on the bottom of the manifold, but today I removed the manifold after having driven 600km and there were again few drops of oil at the seal of each intake port.
    Would so much oil disappear with leaky injectors and wouldn't petrol keep the valve rods clean in the affected cylinders? Without the dipstick it is difficult but through the oil cap I do not feel any fuel smell. Nor did I notice anything strange in oil consistency when I replaced oil after the head gasket change in May.
    Jun 2002
    E39M5, E500 4WD
    It just seems to me that 1 litre every 500 km should make for a whole lot of smoke from the exhaust, and a definitive trail of oil to the combustion chambers, if it's being burned. And, as you point out, that much oil being leaked should also leave a trail. Since we're not seeing either trail, I'd have to recommend more testing, and crankcase vacuum would be the first test. Second test would likely be a leak-down test, to see if you've got a piston-ring issue.
    Chris Powell
    BMWCCA 274412
    Oct 2019
    Argentina
    2008 325i e92
    Bump!im having the exact symptoms as op. Changed following gaskets: oil pan, oil filter housing, oil cooler, rear main seal, vcg. Also changed pcv hose running from vc to intake manifold. No visible smoke from exhaust.
    Things is It apparently consumes oil only on long trips (highway speeds).. aboit 1liter every 500km.
    I have preovuosly changed valve cover from eBay but have normal vacuum númbers apparently.
    Should i check valve seals?
    Op did you resolve the issue?
    What else should i try? I rrslly like this car but its getting under my skin !!
    Oct 2020
    Denmark
    Bmw 523i
    Did you ever find a solution? Having the same issue here....
    Quote Originally Posted by Leinhobmw View Post
    Feb 2021
    Germany
    BMW 325i
    Sorry to hear you are having the same issues as I was. I did EVERYTHING to try and stop the oil consumption on the car but ended up rebuilding the engine in my garage. I made some DIY Youtube videos about it if you're interested. https://youtu.be/-tJ7utqWZQY
    Oct 2020
    Denmark
    Bmw 523i
    Wow, amazing video thread!
  1. What could be causing high oil consumption?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2021, 12:36 PM
  2. N52 Extreme Oil Consumption
    By pureco99 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-13-2021, 04:12 PM
  3. 2006 530i (N52) with oil consumption problem
    By loud in forum 2004-2010 (E60,E61)
    Last Post: 03-31-2015, 07:40 AM
  4. 3.0L oil consumption
    By abellofi in forum 1999 - 2006 (E46)
    Last Post: 03-21-2002, 01:35 AM
  5. Oil Consumption
    By tyl in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2001, 07:23 PM
