Results 1 to 10 of 10
Thread: My bmw e36 has problems starting and staying running.
    Nov 2018
    Kings park
    E36 323i 1996
    Angry My bmw e36 has problems starting and staying running.
    My bmw e36 323i 1996 just randomly started sputtering so i thought i was out of fuel but this wasnt the case as it turned off so i got some fuel and it did nothing. After letting it sit it turned on again but now it sputters when i throttle and if i turn it off it wont start easily. Here is a video of me throttling it and what it does.
    Also Im holding the throttle down in the video.
    https://drive.google.com/file/d/12KM...w?usp=drivesdk
    Oct 2003
    Seattle
    99 M3
    How many miles on the engine and what is your service history?
    Do you have a CE light illuminated in the dash, what are your codes?
    Jun 2010
    NY
    1997 328i
    With you revving the engine we cannot hear anything to help.
    Nov 2018
    Kings park
    E36 323i 1996
    Quote Originally Posted by Eric93se View Post
    Im not reving the engine. Thats me holding sown the trottle its doing that weird rev thing itself
    Nov 2018
    Kings park
    E36 323i 1996
    155000km on the engine and their is no lights on the dash. It has obd1 but i cant check codes as the pedal five times does nothing
    Apr 2015
    Tennessee
    1998 BMW 328i
    Vacuum leaks
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by XnWarden View Post
    Vacuum leaks
    Cracks in intake boot and/or bad vacuum lines
    Sent from my iPad using Tapatalk
    Nov 2018
    Kings park
    E36 323i 1996
    I checked my fuel pressure vacuum lines and intake boot and their are no cracks
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by Major1997 View Post
    Disconnect the brake booster hose to the intake manifold and hook up a vacuum gauge to the manifold port. Check engine vacuum with the car running. Report back with the results.
    Jul 2017
    Aiea, Hawaii
    1997 BMW M3 Sedan
    If its 1996 its most likely OBD2.. and for your issue, smoke test it first before you do anything. I literally used a hand pump from home depot and a black and mild cigar and attached it on the intake manifold where the brake booster hose connects to and smoked it out. Honestly thats your best bet. The pump is less than $10 and the black and mild is $1. If you dont want to do this then goodluck because searching on forums all day wont help if you dont want to do any real troubleshooting instead of just "looking" at places where a problem could be. If you want to know more on how to use this ghetto smoke tester that works 100% then lmk.
  1. Bmw e36 Throttle Problem
    By danyd in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-06-2012, 11:37 PM
  2. BMW e36 318IS not starting
    By sam33r in forum 1991 - 1999 (E36)
    Last Post: 07-24-2011, 03:57 PM
  3. BMW E36 rev problems
    By bekay in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-07-2010, 04:03 AM
  4. BMW E36 ews problem
    By bjazz in forum 1991 - 1999 (E36)
    Last Post: 07-08-2009, 03:21 PM
  5. FS: MINT THULE RACK BMW E36 COUPES $100 starting Bid
    By M3D in forum BMW Parts For Sale
    Last Post: 01-18-2005, 11:10 AM
