Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Bad luck with water leak ....
  1. #26
    Nov 2013
    Whitney, TX
    97 850CI
    Nice job on the top end clean up. Your engine looks great.
    Desecrator of all things Sacred
  2. #27
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    just installed the water pump with the 2 new metal tubes in the valley.... of course with oem O rings and a lot of vaseline.... was worried that it went so easy on... i had expected some more resistance
    I had to order 2 new water hoses to replace the aux heater system... 64 21 1 383 350 is the right one ( connects engine to the additional pump ) but 64 21 1 370 807 seems a wrong hose , and i'm almost certain about the #...… think BMW made a mistake in delivery . It's a short hose from the little metal tube across the valley to the cabin heater. ( The aux system is the same hose but with a melted T in it that go's to the heater )
    I hope i can do a water pressure test before mounting the inlet manifolds ( and wire loom ) …. so i need to install all connections in front with radiator , also shroud with expansion tank... but hope i can still reach and mount the 4 connections under the oil filler .. ? Fan can be mounted later of course.... anybody done this ?
  1. bad interior water leak...ideas anyone?
    By dcs21562 in forum 1991 - 1999 (E36)
    Last Post: 07-27-2012, 11:38 PM
  2. bad rubber seal=water leak?
    By SGB in forum 1999 - 2006 (E46)
    Last Post: 02-14-2008, 10:57 PM
  3. Friday 13th Bad Luck! Radiator Leaking
    By TitaniumSeeker in forum 1995 - 2001 (E38)
    Last Post: 08-16-2004, 12:47 PM
  4. talk about bad luck with a state issued plate!
    By Renee M Coupe in forum Off-Topic
    Last Post: 07-03-2002, 07:16 AM
  5. My Bad Luck
    By Anto Klar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-12-2001, 09:31 AM
