Nice job on the top end clean up. Your engine looks great.
Desecrator of all things Sacred
just installed the water pump with the 2 new metal tubes in the valley.... of course with oem O rings and a lot of vaseline.... was worried that it went so easy on... i had expected some more resistance
I had to order 2 new water hoses to replace the aux heater system... 64 21 1 383 350 is the right one ( connects engine to the additional pump ) but 64 21 1 370 807 seems a wrong hose , and i'm almost certain about the #...… think BMW made a mistake in delivery . It's a short hose from the little metal tube across the valley to the cabin heater. ( The aux system is the same hose but with a melted T in it that go's to the heater )
I hope i can do a water pressure test before mounting the inlet manifolds ( and wire loom ) …. so i need to install all connections in front with radiator , also shroud with expansion tank... but hope i can still reach and mount the 4 connections under the oil filler .. ? Fan can be mounted later of course.... anybody done this ?
