Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: Viscous clutch fan delete ?
  1. #26
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by bdiefAZ View Post
    Another question:
    The aux fan on the Z3 is triggered either by the AC system running or a temperature switch in the radiator and has 2 speeds. Would it be possible to run a larger fan as a puller (more efficient) with this dual purpose setup and use existing wiring from the aux fan? Is there something that I am missing?
    Sorry for the repeated/re worded question, I am not the electrical expert!
    No, you're not missing anything. You can swap from the pusher aux fan to a puller fan using the existing wiring and resistor. A lower temp radiator thermal switch will help mitigate to viscous fan delete. If you want to run both fans at once you should use a relay to power the second fan. Just replacing the viscous fan with a puller fan will not be nearly as effective without also providing a tightly sealed shroud--the bare fan will create a fan shaped cool zone in the radiator immediately ahead of the fan, the fan/shroud combination creates a low pressure zone across the entire back side of the radiator, resulting in the entire surface of the radiator providing cooling. Zionsville makes a shroud paired with a Spal puller (and a radiator) for this purpose.
  2. #27
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    If the viscous fan gets replaced with an electric puller fan for backup, how would you know if either of the two fans ever failed individually? Having the extra backup fan greatly reduces the risk of a fatal overtemp situation, but they both could still fail unexpectantly at some point.
    Does the oem pusher fan produce an instrument panel warning if it fails? If not, is there a means, other than an overtemp condition to monitoring its normal operation like a green light under the dash?
    Many poster’s concern about doing the viscous clutch removal alone is the chance that they could damage the engine if the aux fan alone ever fails.
    How do all the other models running a single electric fan monitor for normal operation and warn the driver of a fan failure before its too late? As others have posted, going to a single fan on our Z3s should be no less risky than any other vehicle running a single fan.
  3. #28
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    I have written hundreds of posts on this very subject, and really don't feel like visiting it again. But, stupid ideas seem to not die.
    The E39 / E46 do have a fan temp sensor. It's at the lower hose rather than stuck in some asinine spot in the tank like ours. And it's a true sensor rather than a switch. No magic, the computer watches the radiator outlet temp and adjusts fan speed to suit.
    Pusher fans are not better or worse than puller. The shroud makes 100 of the difference in fan effectiveness. You will not get as effective a shroud between the radiator and engine as the factory front shroud. I don't care how many gazillion CFM your fan claims, without a proper shroud it won't move as much air through the matrix.
    Thinking that a fan failure means immediate catastrophic engine damage is false. As long as there is liquid in the head, not air, not steam, then the engine will be fine. As long as you run a proper coolant mix and the proper cap (2.0 bar, those who think a 1.2 bar is better need to go back to riding bicycles), the gauge will give you plenty of warning. Yes, the BMW engineers did know what they were doing. Now, if you run pure water, a 1.2 cap, and ignore the gauge (and the steam clouds), then the engine damage is on you, not the fan.
    /.randy
  4. #29
    Oct 2018
    West Bend, WI
    Thanks for your patience.
    I did a viscous clutch fan delete only and will leave it at that. I’d rather deal with a temperature rise than a blown viscous fan.
  5. #30
    Sep 2016
    Yulee, FL
    2000 Z3
    It has been a while and my memory is not great, but I think I remember someone telling me that fan/clutch failure was not an issue for M52B25TU equipped Z3s. Is this correct?
    Stubbornness is a virtue....
  6. #31
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    I wasn't worried about deleting the viscous fan in my '02 540i in the winter. But when I was stuck in stop and go traffic, in August, with the AC on, I started watching the KTMPs. The electric fan did fine and held it's own in all cases. I might install a back-up sometime, but I've been driving it this way for 2 years now with no problems. SO much nicer without the sound of the viscous fan. Prob more fuel efficient too.
  7. #32
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Quote Originally Posted by z3forlife View Post
    You would likely overload the circuit trying to run two fans in the same circuit. There is a thread that discusses adding a additional temp sensor in the return hose from the block
    The fan upgrade consists of removing mechanical belt driven fan and electric auxiliary fan. Once both are removed, a larger electric puller is installed in the place of the mechanical fan utilizing the auxiliary fan's wiring / circuit
    Here is a post from the e46 forum that illustrates the fans:
    https://forum.e46fanatics.com/showthread.php?t=884299
    Regards,
    Brian
    Cave Creek, AZ
  8. #33
    Tim @ BMW of Dallas
    98 Z3 2.8
    Quote Originally Posted by blkwpnz View Post
    That's incorrect. All BMW's equipped with a plastic clutch fan are prone to failure.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
  9. #34
    Sep 2015
    Chicago
    2000 Z3 M Coupe
    One datapoint about the clutch fan: When I asked my mechanic about "parasitic drag" from the clutch fan, he said "Lean in there and spin it with your finger." (The car wasn't running, BTW.) The clutch - if working properly and isn't failed and seized up or something - allows the fan to spin quite freely when disengaged. Whatever the complaints about the clutch fan, the idea of it burdening the engine is probably mistaken.
  10. #35
    Oct 2018
    West Bend, WI
    Agree. Almost all of the horsepower would be applied at the wheels. Air conditioning would be next. Other accessories would be minimal. I seriously doubt that dyno run comparisons with and without these parasitic accessories would detect any difference. I removed my viscous clutch fan to eliminate any future risk of a damaging failure. A side benefit is listening to a fan free engine running with the hood popped.
  11. #36
    Thats removing 1 electric fan and 1 mechanical fan to install a different electric fan
    I dont know why you are trying to reinvent the wheel here. The e46 fan wont fit as I already mentioned and it would draw too much current for the wiring as others have mentioned. And e46 fans were PWM controlled, Z3s have no way to ouput a PWM signal wire. The e46 electric fan conversion is not possible on a Z3.
    If you are this worried just install a new fan clutch... In AZ a fan delete will creep above tdc in some circumstances. No way around that in extremely low humidity and high heat situations
    PRICE CUT on ALL FABRICS
  12. #37
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    Let me get this straight...
    Some here have commented about removing the front fan and adding an electric fan and others appear to claim the front fan can simply be removed.
    I can remove the fan that is attached to the water pump, leave its shroud in place, button up the car and forget about it? No need for an extra electric fan?
  13. #38
    Oct 2018
    West Bend, WI
    Correct. Unless you do commuting with lots of stop and go in super hot weather, the viscous clutch fan (water pump attachment) can be eliminated and you’re done. You still have an electric fan in front of the radiator that’s thermostatically controlled. Same thing I have on both of my toyotas and all the ones I’ve ever owned. Same as my motorcycle as well. Having two fans and eliminating one makes owners uneasy, but having two fans is actually more uncommon than one single fan.
  14. #39
    New England, USA
    2000 2.3 Z3, 2007 328xi
    Step One:
    Step Two:
    “Great wisdom is generous; petty wisdom is contentious.” 无为
  15. #40
    Aug 2016
    Pennsylvania
    Bmw Z3 2.8
    Quote Originally Posted by streetmaster View Post
    Yeah man, i've replaced my pump, along with a new aluminum pulley, and the stock rad, by chance do you recall about how far the fan hub is from the mounting point of the rad, hopefully its around 2.5" considering you're new rad is either thinner or thicker than oem. Im sure ill be golden, yeah that fan drag of the clutch fan drove me nuts lol.
    Mishimoto website says the fan is 2.87” thick. And yes the rad I have is thicker than oem. I had to bend the mounting bracket that comes with the kit so there could be more clearance between the water pump pulley and the fan hub. As it sits now there is less a 1/4” gap.
    And here is where I mounted the relay.
  16. #41
    Dec 2014
    Huntsville, Al
    1999 BMW Z3
    I recently left mine out. No problems yet. I'll consider puttin in the lower temp sensor if I ever see the gauge creep. I don't get into a lot of traffic.
    As to those saying a fan failure will leave me stranded. What??? No, I'll wait for the car to cool and the traffic to leave and then get back on the road. No problemo. I'm much more likely to be stranded because the plastic fan threw a blade trough my hood and is now unbalanced.
  17. #42
    Mesa, Arizona
    2000 Z3 M-Roadster
    The temp gauge is buffered and doesn't reflect changes that would allow you to react to an overheat condition. There's a reason why a fan delete encompasses many steps to be effective. I would trust a mechanical fan more than I would trust watching my temp gauge. Then again, I'm an old fart with poor vision
    Tony
    "You can't sign away negligence."
  18. #43
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Where do you find the lower temp switch for an M52tu. I can't find that info anywhere on any of these threads
  19. #44
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Quote Originally Posted by ihm96 View Post
    Here: https://www.bimmerforums.com/forum/s...S52-fan-delete
  20. #45
    Dec 2014
    Huntsville, Al
    1999 BMW Z3
    Quote Originally Posted by newbimmerguy12 View Post
    It's now late August and it's been a hot summer. Still no problems here.
  21. #46
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    I took my viscous fan out, but later bought a brand new one and installed it.
    Why?
    1) I wanted to try and avoid a catastrophic of the 20 year old plastic fan tearing up my hood, radiator, etc.
    2) I felt that the car was running hot, in stop and go traffic, on 90+ degree days. I used a Bluetooth adaptor to get a real temperature and saw temps that made me a little squeamish.
    My electric fan works and would be on.
    It just didn’t seem worth the little quieter sound to run the engine hotter than it had to be.
    So a new clutch and fan for me. I sleep well believing the fan wont explode, and the engine is as cool as I can make it.
    Greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
  22. #47
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    I've thought of doing the same thing, but don't know how long it would be until I'd stop trusting the new viscous fan. From what I've read, the fan explodes without a warning.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
  23. #48
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    Quote Originally Posted by Tallyho322 View Post
    Why?
    Greg
    I did exactly the same things for the same reasons. The original fan did not explode for 20 years. I suspect the new fan will last 5 to 10 years at which point I'll replace it again.
    In the heat of the summer in Georgia, the viscus clutch engages only after running at speed and sitting at idle for a few minutes or after being parked for a few minutes with the engine off.
    Yes, I can hear the fan when the clutch is engaged. No, that doesn't bother me. I take it as a warning not to run the engine at high revs until it stops - further reducing the possibility of a fan "explosion."
  24. #49
    Oct 2018
    West Bend, WI
    That would be the electric pusher fan in front of the radiator, not the viscous puller behind the radiator. The viscous fan is mechanically driven by the fan belt and will not run when the engine is off.
    The fan belt driven viscous fan behind the radiator is the one that owners are removing because it has a history of disintegrating.
    I was torn about deleting mine, since it only had 20k miles on it. The failures posted shows a big range of miles, so there’s no recommended replacement interval. The possibly of failure at any point and time convinced me to delete it.
    You can’t have everything. Where would you put it?
  25. #50
    Oct 2013
    Augusta, GA
    I know the difference between the sound of the electric pusher fan and the viscous puller fan. The noise to which I refer is never heard when the engine is not running. Also its pitch is directly related to engine RPM.
    I suspect the weakness and subsequent failure of the viscous driven fan is related more to its age and its exposure to heat and chemicals (which causes it to become brittle) than to the miles it has been driven. Although the latter probably has some effect.
  1. clutch fan delete question
    By BOX HEAD in forum 1992 - 1999 M3 (E36)
    Last Post: 09-30-2005, 01:16 PM
  2. Clutch fan delete went terribly wrong!!!
    By 93nitemare in forum 1991 - 1999 (E36)
    Last Post: 01-19-2005, 03:45 PM
  3. WTB cooling fan w/o clutch (fan delete guys!!)
    By neiche in forum BMW Parts Wanted
    Last Post: 09-21-2004, 09:06 AM
  4. clutch fan delete without the kit $10 mod
    By ReVsHoT in forum 1991 - 1999 (E36)
    Last Post: 06-19-2004, 11:41 PM
  5. clutch fan delete
    By 98328I in forum 1991 - 1999 (E36)
    Last Post: 04-22-2004, 09:48 AM
