Results 1 to 25 of 55
Thread: Viscous clutch fan delete ?
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Got a ? about doing an electric fan conversion on my 99 Z3 roadster 2.3, in the process of a cooling system overhaul, also wouldnt mind chucking the noisy wind tunnel sounding clutch fan, which i believe is rated at 2300cfm, im just curious which electric fan other members are using, did some searching, and mostly get (does not fit the Z3), im guessing because of the thickness of the fan assembly. Not sure if it matters, but I did do the M54B25 intake swap, along with new water piping under the manifold, just not sure what cfm to go with on the conversion.
    Johnson City, TN
    2000 BMW Z3 Roadster 2.8
    I can't speak to everyone else's experience, but I just removed mine. Haven't noticed a blip on the coolant temp. My engine is the m52b28/m52tu, the fan that was on my car was new looking, but I was getting a loud clicking noise that I couldn't identify and I realized that it was the fan hitting the front of the VANOS unit. I assume that someone installed the wrong fan.
    Sent from my Life One X2 using Tapatalk
    Long Island, NY
    2001 Z3 2.5, 2021 330xi
    I have the same engine, M54B25, and I just took the mechanical fan out. Didn't add an additional electric fan. Admittedly, I haven't run through all temperature extremes yet but I don't see any change in water temp (and I reprogrammed my gauge to be more sensitive).
    Jan 2016
    Ca
    2001 525it
    The fan clutch is there for a reason, I would recommend either complete your fan conversion or put the fan clutch back on until you do, I mean it's only your coolant system. When the electric aux fan wears out you will be on the side of the road, hopefully not over heated.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Quote Originally Posted by jclausen View Post
    The clutch fan is a backup as BMW was switching from mechanical to electric fans in these years. Later BMWs only have the sole electric fan
    Usually is is recommended to run a lower temp fan switch with the mech fan delete
    PRICE CUT on ALL FABRICS
    Johnson City, TN
    My e83 only has an electric fan
    Aug 2017
    If I remember correctly, the ideal setup for fan removal is to take the visco-fan out and replace the temperature switch in the radiator with the one from the 4-cylinder (lower switching temperature).
    If you leave the visco-fan out and everything else stays stock, your coolant temperature will fluctuate more in the upper range. You'll rarely see it go above 97-99°C with the visco-fan installed, with the visco-fan removed it will go up to 105°C during the summer before the electric auxiliary fan kicks on and brings the temperature back down.
    Aug 2016
    Pennsylvania
    Bmw Z3 2.8
    Quote Originally Posted by me77 View Post
    This is exactly what I experienced, and I read somewhere that the optimal operating temp is 190F so I went with the 16” slim Mishimoto fan kit and paired it with the radiator they sell and turned out perfect. The fan moves 1850cfm. I even wired a switch through the firewall (below the fusebox) so I can override the temperature probe if anything. Im pretty sure you can just buy the fan kit and itll mount right up to the radiator.
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Yeppers, I was looking at the Mishimoto 16" fan setup, I guess its a replacement for the clutch hub fan on the E36, but also said it wouldn't work on the Z3, apparently it does, wasn't sure for fear of it coming in contact with the water pump.
    Aug 2016
    Pennsylvania
    Bmw Z3 2.8
    It is very tight especially with the rad im running. You can measure it out with a caliper just to be sure it fits in your setup. Im also running power pulleys from turner, not sure if they are any slimmer than oem.
    Feb 2015
    Uniontown, PA
    1999 Z3 roadster
    Yeah man, i've replaced my pump, along with a new aluminum pulley, and the stock rad, by chance do you recall about how far the fan hub is from the mounting point of the rad, hopefully its around 2.5" considering you're new rad is either thinner or thicker than oem. Im sure ill be golden, yeah that fan drag of the clutch fan drove me nuts lol.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Regards,
    Brian
    Cave Creek, AZ
    Quote Originally Posted by bdiefAZ View Post
    Dont think so and those electric fans wont fit the z3 properly either. Did some research on that recently myself...
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    Just got my M Roadster and will be deleting clutching fan first chance I get. Will be logging water temps on each outing through the 2019 summer season. My typical treks will be 75-100 miles each. If it behaves through hot weather (Wisconsin 90s F), I’ll leave it with fan delete only. I will not be commuting or in stop and go traffic, so I’m confident it will be fine. Will post results around this time next year. Both my motorcycle and roadster are not looking forward to winter storage. :-(((
    Fan deletes seem fine until about 95-100+ degree weather only with extremely low humidity. Any other situation the cars are fine as-is without em. Lower temp fan switch helps too.
    Oct 2018
    West Bend, WI
    Viscous clutch fan removal done. I had a big old 1 3/16” open end (slightly too big, but worked) that broke it loose easily. Tight removal space, but finessed it out. Removal only with no other changes with optional fans, thermostat, etc.
    We’ll see what future water temps do. Should be fine and don’t have to worry about exploding part damage. The mileage is low at 20k, but it’s still 20 years old. I don’t know what internal deterioration is possible, but I’d rather not take that chance. It also sounds better with a dominate exhaust rumble versus hoover vacuum cleaner sound under the hood.
    Cave Creek, AZ
    Is the electric cooling fan on the M54 powered Z3 controlled by the ECM or via thermal sensor on the radiator?
    Regards,
    Brian
    Cave Creek, AZ
    Thermal switch, they did not switch to the DME controlled PWM system on Z3's
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Spal VA08-AP51/C-23A fits properly. There was one more Spal model a bit thicker (I think by ~20mm) and quieter which probably should fit as well.
    Quote Originally Posted by BimmerBreaker View Post
    M44 (or M43 don't remember exactly which) thermal switch signal for sure is going through DME. I know that because I helped someone diagnose problem, we found out that DME was the culprit (and I have no idea why it has to go through DME there).
    Cave Creek, AZ
    Does that apply to the M54 cars?
    Regards,
    Brian
    Cave Creek, AZ
    Quote Originally Posted by deni2s View Post
    Yes but E39 M54 cars for instance dont have that radiator mounted thermal switch they use DME magic coupled with temp at thermostat and other stuff to determine if fan works and at what particular variable speed.
    Z3s never got the PWM fan setup, all Z3s have rad mounted temp sensors and use them for coolant fan trigger points is what I was saying.
    Yes... I was replying to a post about you asking about M54s
    ALL Z3s regardless of engine operate like that
    Cave Creek, AZ
    Another question:
    The aux fan on the Z3 is triggered either by the AC system running or a temperature switch in the radiator and has 2 speeds. Would it be possible to run a larger fan as a puller (more efficient) with this dual purpose setup and use existing wiring from the aux fan? Is there something that I am missing?
    Sorry for the repeated/re worded question, I am not the electrical expert!
    Regards,
    Brian
    Cave Creek, AZ
    Mesa, Arizona
    2000 Z3 M-Roadster
    Using the search feature will provide an immense amount of information surrounding the mechanical fan removal. This topic has been discussed at length and in great detail over the years.
    Tony
    "You can't sign away negligence."
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Another question:
    You would likely overload the circuit trying to run two fans in the same circuit. There is a thread that discusses adding a additional temp sensor in the return hose from the block
  1. clutch fan delete question
    By BOX HEAD in forum 1992 - 1999 M3 (E36)
    Last Post: 09-30-2005, 01:16 PM
  2. Clutch fan delete went terribly wrong!!!
    By 93nitemare in forum 1991 - 1999 (E36)
    Last Post: 01-19-2005, 03:45 PM
  3. WTB cooling fan w/o clutch (fan delete guys!!)
    By neiche in forum BMW Parts Wanted
    Last Post: 09-21-2004, 09:06 AM
  4. clutch fan delete without the kit $10 mod
    By ReVsHoT in forum 1991 - 1999 (E36)
    Last Post: 06-19-2004, 11:41 PM
  5. clutch fan delete
    By 98328I in forum 1991 - 1999 (E36)
    Last Post: 04-22-2004, 09:48 AM
