The N55 Eventuri intake system is a perfect example of Eventuri's “Complete System” principal. It demonstrates the perfect balance between allowing for unrestricted airflow with their open filter housing and cold air saturation with our scoop and duct combination. Every detail has been meticulously developed from the prepreg carbon pieces to the precision bracket work. This intake sets a new benchmark in design and craftsmanship for the F22 and F87 platforms. Also fits the F30 and F32 chassis with the N55 engine.
The N55 Eventuri system uses their Patent Pending Carbon fibre Housing which provides an aerodynamically efficient airflow path from the filter to the MAF tube. Not just another cone filter with a heat shield but a unique design which invokes the Venturi effect.
Each kit consists of:
- 100% Pre Preg Carbon Fibre Housings
- High Flow Air Filters
- CNC Machined and Anodised Aluminium MAF Sensor Housings with Machined Plastic MAF Sensor Mounts
- CNC Machined Secondary Air Flow Breather Adapter
- Aluminium Intake Cowls
- Laser Cut Mounting Brackets
- Laser Cut and Neoprene Lined Heat Shields
- Coated Aluminium Upper and Lower Air Scoops
- OEM Spec Hose Clamps with High Quality Silicon Couplers
