Results 1 to 6 of 6
Thread: X3 Can't reset transfer case adaptations in ISTA-D, tried everything I can think of
    Nov 2009
    Whitefish, MT
    E34 525i/5 . E39 540i
    Unhappy X3 Can't reset transfer case adaptations in ISTA-D, tried everything I can think of
    Hi guys,
    I'm working on our 2008 X3 and I recently got the 3 lights (4x4, brake, abs). I lifted it up on the rack and just as I expected, the internal gear for the servomotor was worn smooth.
    I've since replaced the gear and now when I start the car, it goes straight into 4x4 rather than 2wd.
    Upon plugging into the ISTA-D, I'm able to read out the amperage and degree position of the servo motor and can watch the degrees and amps sweep when I start the car.
    When I go into "vehicle management" > "service functions" > "Powertrain" > "Transmission control unit VTG" > "Repair" > "ABL Transfer box" repair" and select any of the options to reset the transfer case adaptation, it will read the calibration resistor as "Code G", then attempts to calibrate the servomotor. I hear it move back and forth in the case, but it last about 4 seconds and then results in "The function could not be performed fault-free" "Try again 1 Yes/ 2 No".
    Doesn't matter what I do, it always results in this error.
    The car was operating perfectly before the gear died, and now I can't get it to adapt again.
    Any pointers?
    E36 problem in the E34 forum:
    Quote Originally Posted by Mordan View Post
    I'm here because the E34 guys are knowledgeable and mature. Besides I own an E34 and it is my favorite.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    I used the NT520 to reset mine but i think you go into Oil Change instead of Repair for the adaptation reset.
    What do you mean by it goes into 4x4 instead of 2wd?
    Nov 2018
    2008 BMW X5
    You should not have to reset the adaptation because of this failure!
    If re-assembly of replaced gear, servo-motor to the transfer case and both cables/connectors are attached correctly to the servo-motor then (4x4, brake, abs) should disappear immediately after the car is driven a few yards away.
    Apr 2019
    USA
    X3 2008
    Did you ever figure out how to solve the ISTA/D "The function could not be performed fault-free" problem? I am experiencing the exactly same problem and am stuck with BMW triad of lights at the moment and "VTG: Faulty calibration" code.
    A little bit of history about my car:
    I had triad of lights so I replaced gear on my X3 and did not reset anything with ISTA/D. Triad of lights went out on their own.
    However, my car was juddering big time on sharp, slow turns. So I also replaced TC fluid and successfully reset adaptations through ISTA/D (TC oil change wizard. Not the one you picked up). This helped a lot with juddering.
    However, there was still a little juddering when car engine heated. So I took servo motor out again. Greased it liberally, put back and this time picked the "vehicle management" > "service functions" > "Powertrain" > "Transmission control unit VTG" > "Repair" > "Exchange transfer case servo motor". And that's when I ended up in the same situation as you.
    I think this either means:
    1. we both picked the wrong ISTA/D "service function" that triggered this issue. I.e. a software glitch.
    2. when I took servo motor out second time I may have not put something correctly back in.
    Nov 2009
    Whitefish, MT
    Solution
    Although my transfer case motor tested fine when it wasn't bolted to the car, replacing it completely was the only way I was able to get ISTA to calibrate properly. I bought an OEM motor, but it's likely that an aftermarket motor would have fixed the problem as well.
    Cheers
    Apr 2019
    USA
    X3 2008
    Quote Originally Posted by rotaryboots View Post
    Cheers
    Thanks a lot! This gives me a hope that my problem hopefully is also in servo motor.
    Few followup questions:
    1. What do you mean with "my transfer case motor tested fine when it wasn't bolted to the car"? Was the test just to observe that the servomotor gear spins under no load?
    2. Did you also try to isolate issue to the transfer case servo resistor by replacing it during your troubleshooting?
    3. Do you recall if you by accident somewhat pulled out worm axle from servo when replacing the gear? The second time I opened up the servo I was not careful enough and pulled out the axle a little bit out. The first time I was super careful and it did work fine.
  1. Transfer Case Adaptation Reset - What are my options?
    By Auto Parts Guy in forum 1999 - 2006 (E46)
    Last Post: 03-09-2024, 09:51 AM
  2. X3 2006 Transmission and Transfer Case Drain and Refill
    By fun2drive in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-11-2019, 05:33 PM
  3. BMW X3 2004. Diagnostic computer error message "5dea Transfer case Temperature
    By Northcliff in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-09-2017, 01:13 PM
  4. 2004 X3 Clunking noise braking (transfer case ?)
    By ryster in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 04-12-2017, 10:47 AM
  5. DIY - Changing X3 transfer case fluids
    By Borderline in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-28-2008, 01:18 AM
