Results 1 to 6 of 6
Thread: Correct Power Steering Fluid Dexron II for 2007 E87
    Aug 2013
    United Kingdom
    2007 BMW 120i E87
    Surely this information already exists somehwere, but searching the forum for Dexron draws a blank oddly...
    "Traditionally" Dexron II is the correct Power Steering Fluid for most BMWs I've encountered , but the E87 is the newest BMW I've had and I want to be 100% certain..
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    What does your user manual say? No sticker on the reservoir lid?
    On my 1988 E32 750 there is a green sticker which mentions that this model with self levelling rear shocks and dual power steering pump + hydraulic brake booster needs Pentosin CHF 7.1 special power steering fluid (not ATF)
    Aug 2013
    United Kingdom
    2007 BMW 120i E87
    Owners manual only mentions the engine oil spec.
    I know some take Pentosin but usually there is a green ring on the reservoir that says so.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Actually, Dexron3 has been the go to fluid for the power steering system. That and a more exotic Pentsoin fluid. My current bimmer’s fluid is electricity. It has electric steering. Gott im Himmel.
    Jan 2005
    Japan
    realoem shows for a 2007 120i E87 RHD 2 versions, Pentosin CHF 11S or ATF, depending on the label, see here http://www.realoem.com/bmw/enUS/show...diagId=32_1513
    I am no expert for the E87, let's wait till someone else chimes in with E87 knowledge
    What is the VIN?
    does it have a green cap or has active suspension ? https://www.bimmerforums.co.uk/forum...fluid-t135217/
    Nov 2020
    Australia
    120i 2007
    Hi I am having problem with starting 120i 2007 E87 can not start and I diagnosed and it says DME main delay and I can not find exact location where it is and is any one know that where DME main relay is located.
  1. Dexron II or III for the power steering fluid...
    By fishbulb in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-19-2014, 11:59 AM
  2. Let's make a correct power steering fluid flow chart
    By Layne in forum 1988 - 1996 (E34)
    Last Post: 02-11-2014, 11:24 AM
  3. Correct Power steering fluid for 2002 M Coupe...Dextron ATF III?
    By ammolab in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-08-2012, 09:33 AM
  4. Replies: 1
    Last Post: 03-20-2008, 12:04 PM
  5. Power steering fluid: Dexron III or IV?
    By billhao in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-26-2007, 09:00 PM
