When I was trying to do the research on how to make these wheels fit, I found next to no helpful information so I decided to make this short thread on how to make these wheels fit. My goal from the beginning was to have a more stance look, while still being able to drive the car hard as it is still my daily driver. One of the reasons for wanting to run M Pars was that I realized because they were 18s, I could have good fitment without being super low to the ground, making the car more driveable. Let's get into the wheels themselves:
These are Style 37's off of an e38, meaning the specs are 18x8 et13 front, and 18x9.5 et25 rear. This is how they looked when I initially test-fit them:
Front
Rear
This made me pretty nervous, especially when I saw how much the front was poking. The only fender modifications I've made was a slight roll on the rear fenders. After a asking for many opinions and lots of useless research, I bought 205/40 and 225/40 Michelins and heres how they fit now:
I did end up raising the rear a bit haha. So here are the final specs of everything along with a couple other pics:
Wheels: 18x8 et13, 18x9.5 et25 e38 style 37's
Tires: 205/40, 225/40 Michelin Pilot Sport A/S 3+
Suspension: Broadway Static 500s coilovers (comes with camber plates), -1.7* rear camber, and -3* front camber. Stock rear camber arms.
Fender mods: Slight roll on rear fenders, N/A for front. May end up having the inside of the fenders shaved so I can run it a little lower/tighter.
TL;DR They aren't as difficult to fit as people seem to think. If you want to be a hotboi all you really need is coilovers with camber plates and you're good, otherwise you can go for a meatier tire setup if you are fine with being higher up off the ground. Hopefully this was helpful for a few of you out there. I know it would have been for me
Looks amazing!
Wheels look nice but those tires are way too skinny for my taste.
Wow, those are big wheels for an e38.
Current fleet:
1999 BMW e36 M3
1999 BMW e36 328is with rotary valve engine head
1999 Oldsmobile Eighty Eight
1990 Jeep Comanche Eliminator
1962 Austin Healey Sprite
Thanks man!
Do it!
Haha has to be done if you want to be this low/fitted
you mean e36? Was pretty unsure if I'd like the look of 18's on an e36 but they've grown on me a ton, would definitely run another set of 18's
