Hello,
The two tabs on either side of the horn on my steering wheel needs to be repainted. The color is Estoril Blue. I found a few sights that sell Estoril Blue in a spray can, however, I assume that it is matched to the exterior color. Has anyone tried spraying any interior trim with the Estoril Blue spray can? If so, can you share results? Or, if anyone has been able to more closely match the Estoril Blue interior trim with a similar color I'd appreciate knowing the color. Thanks for your advice.
I was looking at ECS steering wheel options the other day and I think they might still stock that part if you end up deciding to just shell out money for a new part. Mine has the plain black inserts but Ive seen an Evergreen coupe that had colored inserts and they looked sweet so good luck restoring yours. Im sure theyll look awesome
