Results 1 to 6 of 6
Thread: Oil Pressure Switch & Temperature Sensor - Oil Filter Hosuing
    Jan 2012
    NYC
    2003 530i, 2005 X5 3.0
    Hello all,
    I am currently in the middle of doing the oil filter housing gasket on my 2003 530i manual. I would like to know if the temperature sensor # 13 and the oil pressure switch # 12 have any gaskets or crush washers? I have looked at real oem and did not see anything. http://www.realoem.com/bmw/enUS/show...diagId=11_7537 I would like to remove them so I can properly clean the oil filter housing since it is out of the car. Thanks.
    San Jose, CA
    1997 BMW 540i 6 speed
    Why not remove them and see? I'm sure there are aluminum or copper washers used.
    Omaha, NE
    1998 528i 5-spd 102K
    The sensor(s) come with washer.
    I posted photos in the thread below.
    See my post from July 14, 2018:
    Low Oil Pressure warning--possible cause
    https://www.bimmerfest.com/forums/sh...php?p=12633444
    Jan 2012
    NYC
    Thanks alot CNN, I should have bought the new sensors as they do not cost to much. I am debating whether to buy the parts and wait, clean the OFH without removing them, or re-use crush washer (last resort)
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    You can buy different sizes copper and aluminum crush washers at most any autoparts store. They are cheap, good to have some spares on hand.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    Match the specs correctly. Some are tin coated copper, and some are soft aluminum, depending on the metals they seal against.
    But those washers are pretty much captive -- it will be difficult to change them. They usually re-seal with no problem if you follow the torque spec.
  1. How do I install the oil pressure switch/sensor
    By 7FORTYIL in forum 1995 - 2001 (E38)
    Last Post: 06-01-2010, 03:13 AM
  2. Oil pressure switch location for euro oil filter housing?
    By ltbrkm3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-19-2010, 12:31 PM
  3. Stock Bosch oil pressure "switch" - is it a switch or a sensor?
    By 5mall5nail5 in forum Forced Induction
    Last Post: 11-07-2008, 11:49 PM
  4. Replacing Oil Pressure Switch
    By ukray in forum 1996 - 2003 (E39)
    Last Post: 08-12-2005, 11:02 AM
  5. Oil pressure switch on the M42 engine???
    By Gonzo318is in forum 1983 - 1991 (E30)
    Last Post: 12-24-2004, 12:47 PM
