Hi everyone, I'm going to start upgrading the audio on my Z3 (2.0 2000 Manual Roadster) with the amplifier. No doubt new speakers will be next, but on their own, I know I won't be satisfied - I've tried this once before. I really want to see what difference a decent amp makes before I look at speakers and a proper subwoofer enclosure. (I know the stock speakers are not 4 Ohms and the new amp will run at that I guess, but even so, I want to see what improvement the amp alone provides.
What I would like to do is use the existing wiring (and speakers for now) and simply replace the amp in the boot/trunk with a good one. I don't have the Harmon Kardon system, but the mid-model HiFi, which has a single Alpine amp driving all speakers, including a philips subwoofer, which looks a little different to the HK one, but fits in the same place in the car.
I'm happy with the stock CD43 head unit and have a cheap bluetooth adapter that works nicely, so am not interested in running new RCA cables from an aftermarket head unit to the new amp. I want to stick with the existing wiring.
Ideally, I'd love the female connector that is in the amp, with pigtail wires so that I can avoid cutting the wiring loom. I think finding this is VERY unlikely as it is a pretty unique plug. (I guess I could track down a broken Alpine amp and sacrifice it to get the plug....if anyone has a dead amp, please let me know!!) More likely, I will need to cut or tap the individual wires in the loom in the boot/trunk and connect the inputs and outputs to the new amp.
So my question is, does anyone have the colours for this wiring loom that passes into the Alpine amp so I know what to tap? It could be the colour coding is the similar to the Harman Kardon setup, but I don't know and google has failed me with a definitive picture.
Does anyone have experience with this?
Thanks!!!
Jeff
Check the website "wedophones".com for a wiring diagram
Maybe you can find it here http://drrobertryandundee.com/wiring...g-diagram.html
thanks guys. No luck as yet, but will keep searching. (that second site seems a little suspicious DimrBimmer. Have you signed up to it?)
I didn’t. But I was able to bring up some images of z3 alpine stereo back with pinout and explication what pin is what.
Disable JavaScript or get a web browser that lets you toggle text only browsing on and off. It should land you on the page without a pop up and all diagrams. I use TextBrowser on my iPhone.
No offense:
-You should really start with the speakers especially if they are original.
-There are 2 amps that come with HK (at least USA) unit - so you may also have a subwoofer amp.
The only original component I have left is the multi channel amp - which when fed by the speaker out (hi level) from head unit is a glorified active crossover..
“Great wisdom is generous; petty wisdom is contentious.” 无为
http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
Take a look here
