This car is a brilliantrot 1991 BMW 325ix 5-speed, fully loaded. It has almost 290,000 miles and I am the 2nd owner. I've had it since 1997 and it has been 1/2 garaged and 1/2 outside. The paint is a bit faded, but polishes nicely. It has some small dents and scratches that are normal for a 27-year-old car. It has never been in a crash and has no rust. All of the interior lamps and gauge lights work, as do the controls and switches. I change the oil and filter with a Mann filter and Castrol GTX 10w-40 every 3000 miles. The car just passed the OR emissions test in December 2017 and is registered through December 2019. The car also gets Redline driveline fluids at factory-specified intervals.
Spec includes:
- Black leather interior (recently reupholstered driver's seat bottom with new factory seat heat element)
- Black dash with no cracks
- Premium sound (original BMW radio/cassette deck)
- Full size spare
- Ski pass-through
- Original heated seats
- Airbag
- Original BBS wheels (incl. spare)
- Full original tool kit
- Power windows and sunroof
The car has very few modifications. They are:
- Bilstein shocks
- Braided brake lines
- Drilled front brake rotors
- Stainless exhaust from manifold rearward
- ABS off switch
Recent service includes:
- Newly rebuilt cylinder head (valves, camshaft, rockers)
- New distributor cap and rotor
- New cambelt and tensioner
- New water pump
- New radiator
- New ignition wires
- Newly re-sealed transfer case
- Newer steering rack
- New leather and padding on driver's seat bottom with new OEM heating element
- New heater valve
- New clutch/pressure plate/throw-out bearing (<1000mi)
- Fresh Redline fluids in both differentials and transfer case
As with any old car, there are a few areas that need attention (or not). They are:
- A/C compressor - it hasn't worked for 15 years. I don't use it, so I never fixed it. It may just need to be recharged.
- Reverse lamps - they don't work because the switch is bad. It's on top of the transmission housing. It's cheap and easy to fix. I'm just a bit lazy.
- Transmission – it works fine, but whines softly in 3rd gear. It's old and likely could benefit from a rebuild.
- A/C blower fan – may be fan failure, but could also be a relay issue.
Full photos and video here:
https://flic.kr/s/aHskCJUaVi
I'll give you 2800.
Still available?
Nice ix! Still for sale?
BMW fleet...
2023 X5 4.0Xi
2012 F650GS
2007 F650GS
2006 F650GS
2002 325iT
1999 Z3
2003 530i (son's car)
1996 318ti (son's car)
Departed BMWs...2011 328i...2009 328i...2001 325i...1998 328is...1997 328is...1997 328Ti...
