Results 1 to 7 of 7
Thread: Question for the 6 speed swap guys
    Altamont, TN
    2001 540i/6, 2000 740i
    HI Guys,
    I am gathering the parts to do the 6 speed swap into my new to me e38.
    On the issue of the bent selector rod and the shifting arm,
    http://www.realoem.com/bmw/enUS/show...diagId=25_0009
    Items 2,4
    Did any of you try to source the parts from Germany through ebay?
    I found 2 auctions that have the parts listed with the correct part number for the Europe e38 740i with manual transmission,
    https://www.ebay.de/itm/Shifting-Arm...zQIT:rk:1:pf:0
    Is there any downside to going this route, rather than trying to extend a 540 linkage?
    Tony
    Greenville, SC
    01 749iM/6 sporty
    It's your money. I weld the selector rod myself and give a guy a few bucks to do the aluminum.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
    Altamont, TN
    007008,
    Did you extend the UUC double shear rod on Rave34's car?
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by viking89 View Post
    007008,
    No, a friend of his did it.
    Trevor
    81 Delorean,B28F
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I am interested in a 6-speed swap on a V12 and I have just started reading the threads I can find. What flywheel and clutch assembly are most people using for a street car with normally aspirated engine? Thanks,
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by JDP530 View Post
    The clutch and flywheel from the 850. Do you have a line on a transmission? Have you look into pricing?
    Trevor
    81 Delorean,B28F
    Dec 2013
    San Antonio
    Quote Originally Posted by 007008 View Post
    I have a '91 850i automatic and I do like to track my car and even autocross it when I don't run my formula car. I would probably do the 420G swap and use the PMC adapter plate. These transmissions are pretty common and sell for $800-1200. Supposedly, PMC offers a flywheel but I did not see it on their website.
    I did not think the 850 flywheel was still available but I will check shortly. I see where the dual mass flywheel is available from several suppliers. Will it clear the PMC adapter and is there some type of flywheel spacer available to make up for the adapter plate?
    Thanks,
    JP
  1. Question about 5 speed swap
    By heifetz17 in forum 1988 - 1996 (E34)
    Last Post: 09-09-2016, 08:58 AM
  2. Newbie question about 5 speed swap
    By black 97 in forum 1991 - 1999 (E36)
    Last Post: 08-30-2011, 12:08 AM
  3. All you 5-Speed Swap Guys & Gals
    By jetavdk in forum 1999 - 2006 (E46)
    Last Post: 01-07-2010, 10:13 PM
  4. Quick question to m50 5 speed swap guys
    By birkire in forum 1988 - 1996 (E34)
    Last Post: 02-23-2009, 01:40 AM
  5. Questions about 6-speed swap in 540i
    By JV1021 in forum 1988 - 1996 (E34)
    Last Post: 10-12-2006, 02:42 PM
