RM European Auto Parts
Results 1 to 5 of 5
Thread: Clutch problems
    Nov 2018
    Bloomington Indiana
    1994 325i Convertible
    Clutch problems
    So i own a 1994 325i with a 5 speed manual. And today as i was going to downshift i pushed in the clutch and it had no resistance and just stayed on the floor. Now this was and wasnt just out of nowhere, my car started doing weird things yesterday where it wouldnt come out of or go into gear unless i let out of the clutch while in neutral and then pushed it back in. I was told it’s probably just a bad slave cylinder as there still seems to be fluid in the system, is there any way to actually tell what it is without going and replacing things first?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Check very carefully whether there is brake fluid dripping from the bottom of the transmission bellhousing, Even better, unbolt the slave from the transmission, without undoing the hydraulic line, and see whether it's wet.
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    If you aren't loosing fluid it's not the slave. A failed slave always leaks.The master can be bad without leaking externally.
    A failed master can have bad internal seals which allow the piston to move without displacing enough fluid to actuate the slave. It doesn't leak but it still doesn't work.
    Your need for "double clutching" is indicative of the clutch not being actuated fully. Probably one of the above items.
    Nov 2018
    Bloomington Indiana
    1994 BMW 325i Manual
    I need to buy a new hose to run to my slave cylinder. Any suggestions?
    Jun 2002
    E39M5, E500 4WD
    Chris Powell
    BMWCCA 274412
  1. fan clutch problem!!
    By neaks325i in forum 1991 - 1999 (E36)
    Last Post: 06-09-2002, 02:29 AM
  2. Trans/Clutch Problems
    By BlackMroadster in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-24-2002, 02:06 AM
  3. clutch problems?!?
    By rcshan in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-06-2002, 01:19 PM
  4. Clutch Problem
    By ///M3Dave in forum 1992 - 1999 M3 (E36)
    Last Post: 08-07-2001, 01:22 AM
  5. Clutch problems
    By DMD///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-06-2001, 06:50 PM
