Results 1 to 3 of 3
Thread: Rear quarter window alignment after installing new softop
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    I installed a new Haartz stayfast softop and the new top is obviously much tighter than the one I replaced. I’m now having trouble getting the rear quarter windows to align with the door windows. There’s a gap at the top of the vertical window seal. If I raise the quarter windows with the doors open I can wiggle them into place at the top of their travel and then the front door windows seal as designed. But it’s hit and miss while raising them together after having the top down. Any tips for adjusting these?
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    quarter windows have screws that allow for adjustment. Remove your lateral panel and you will see a couple bolts that are actually the star shaped holes with a nut. Loose the nut, turn the star bolt to the desired place and tighten.
    They can adjust forward and rear, in and out.
    Jun 2016
    North Carolina
    Updating in case people find this thread in the future. The upper nuts Greg mentions are 13mm and the torx screw is 20mm. I found I also had to loosen the two lower 13mm bolts (no torx screws) in order to get the window aligned vertically before adjusting the upper nuts and screws. This worked and I now have the quarter windows aligned with the new top and sealing well against the front windows.
  1. New DIY Rear Quarter Window Regulator w/pics
    By M3rocket in forum Convertible Questions
    Last Post: 06-18-2020, 02:17 PM
  2. Instructions for installing fixed rear quarter windows?
    By alpinewhite318i in forum 1983 - 1991 (E30)
    Last Post: 09-12-2016, 12:14 PM
  3. E36 FS: New Rear Quarter Window Gasket
    By hezamhm in forum Interior Lighting & Body Parts
    Last Post: 06-04-2011, 07:06 PM
  4. FS: Brand new OEM rear plastic window w/ an install kit
    By MKit in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-01-2007, 02:20 AM
  5. Alignment needed after installing New Wheels??
    By M325M in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-30-2003, 02:51 AM
