Results 1 to 25 of 58
Thread: Poor fuel economy ( help please )
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Hello every body , my car ( e38 1997 740 eur ) has poor fuel economy with moderate driving . city 4 km / l , highway 6.5 km /l
    no errors except for map cooling , bank 2 o2 sensor .
    maf , injectors , plugs purge valve , fuel filter , fuel pump and engine gasket are replaced with no change
    I have rough cold start with low power but its fine when get hot . only fine roughness at idle and sometimes tiny hiccup at rpm 2k when car in parked otherwise the acceleration is very good . I upload some pic from inpa , smoothness is shown to irregular I switch off the coils and no change .
    IL
    2000 740i sport
    A bad thermostat and upstream o2 sensors can lead to bad MPG. Bad intake gaskets can also potentially cause false o2 errors from the additional air it is pulling in before the engine gets hot and expands the gasket a bit. I had a bad cold start idle and an intake reseal resolved that. All new intake gaskets and TB gasket. Might consider doing the valley pan while the intake is out too...
    Sent from my SM-N960U using Tapatalk
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Your adaptation values do not support an O2 error - unless you have cleared adaptions just before you took the screenshots, or, the O2 sensor is dead. What was the O2 error?
    My BMW Repair YouTube Channel
    Mar 2014
    Iraq
    1998 BMW e38 740i
    poor fuel economy ( help please )
    Quote Originally Posted by purplecty View Post
    Thank you Purplecty
    Regard o2 sensors previously I had 2 working sensors and the problem still
    , can I use some sort of sealer rather than new gasket ?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Thank you Timm
    I am thankful for you regard your site and the huge information in it .
    Recently I did adaption but previously the additive not fixed I saw it -2 and +2 from different times, multiplicative is -4 or near that value
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I would guess then that the O2 error was not an 'adaptations at limits' and is a real O2 error. In which case, as purplecty says - you won't get good MPG until that problem is fixed by replacement of the Lambda sensor...
    Mar 2014
    Iraq
    1998 BMW e38 740i
    My o2 sensor is Bosch , but for e34 I transfer the connector , I can see it goes up and down by inpa ! .
    If the vac leak with in adaption limit the car can run smoothly with no effect on economy ?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    All explained here:
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Here is the gasket
    IL
    2000 740i sport
    Quote Originally Posted by haydar alameen View Post
    Here is the gasket
    Replace all of them even the ones on the front and rear and the throttle body one as well...
    https://www.fcpeuro.com/products/bmw...et-11611433328
    https://www.fcpeuro.com/products/bmw...et-11611729728
    https://www.fcpeuro.com/products/bmw...or-11611729727
    https://www.fcpeuro.com/products/bmw...et-13547510433
    IL
    2000 740i sport
    Any luck?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Any luck?
    Thank you my friend,
    I removed the intake manifold and replace the gaskets the engine runs better but economy is the same ( I install universal Bosch o2 sensor at the same time , may be problem with it !
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Update , It was the manifold gasket which cause poor power and rough idle , economy is still and I will give you feedback
    IL
    2000 740i sport
    Why universal o2s? The direct fit bosch ones are cheaper and plug and play...
    https://rover.ebay.com/rover/0/0/0?m...2F252282318699
    Mar 2014
    Iraq
    1998 BMW e38 740i
    All explained here:
    Thank you Timm
    I saw your videos previously , its simple and very informative .
    Regard the o2 sensors it should be oscillating on inpa or not , I use the reading of l/ h from test 4 and I see there is no correlation with voltage changes of the sensors in inpa !
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Unfortunately I do not get it I lives in Iraq
    IL
    2000 740i sport
    Oh ha woops didn't recognize that... So the intake gaskets resolved the cold start idle?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Yes
    IL
    2000 740i sport
    Yes
    Great! Did you reset adaptations after installing the o2s?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Surely yes
    IL
    2000 740i sport
    Surely yes
    Keep us posted...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Thank you Timm
    When the engine is at running temperature the pre-cat O2 sensors should be swinging around the scale - the O2 sensors are narrow-band devices and can only detect if the mixture is too lean or too rich (unlike wide-band O2 sensors which provide a linear reading of oxygen levels).
    The DME is constantly adjusting the fuel/air mixture - it increases the fuel when the O2 sensor shows the mixture is too lean and reduces it when it detects the mixture is too rich - it does this constantly so the O2 voltage swings around. The adjustments are quite small - but the O2 sensors are very sensitive.
    The integrated Lambda reading is the filtered and integrated Lambda reading and gives a true reading of the average fuel/air mixture - it is that value that is worth watching - all explained here:
    https://www.meeknet.co.uk/E38/Diagnostics.htm
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Keep us posted...
    Ok I will do this
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Ok . So if the reading is fixed at for example 0.50 it means not working sensor ?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I read the inpa values today it was -7 in additive in both side , zero in multiplicative in both sides
  1. help! m60 failed smog, poor fuel economy
    By reubeng in forum 1988 - 1996 (E34)
    Last Post: 10-30-2015, 10:46 PM
  2. remote started shorted out NO SIGNAL to fuel pump HELP!! please
    By roadkill1991 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-26-2008, 03:19 PM
  3. replacing intank fuel strainer HELP!!please
    By sn1928357 in forum 1983 - 1991 (E30)
    Last Post: 06-14-2007, 10:59 PM
  4. Bad O2 sensor w/o CEL? (and poor fuel economy)
    By Jason C SBB in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2007, 05:07 PM
  5. poor fuel economy
    By SoCalBMW in forum 1991 - 1999 (E36)
    Last Post: 01-26-2006, 08:52 PM
