Results 1 to 8 of 8
Thread: bmw e39 1997 520i, is it obd2 compliant?
    Nov 2018
    norway
    1997 bmw e39 520i
    i have a bmw e39 1997 520i and i was wondering if it is obd2 compliant? i dont have an obd port under the steering wheel only a round one under the hood, i cant get my obd scanner to work it only says error, plz help
    Nov 2018
    poland
    525eds
    nope. that one is the engine bay under the hood job... big round circle bundle of joy. i know this as mine i a 525tds from the same year. the same goes for the E36#s
    Nov 2018
    norway
    1997 bmw e39 520i
    Quote Originally Posted by justinlucking View Post
    so even if i got an adapter from round 20 pin to flat 16 pin, my obd2 scanner wont work?
    i tried an adapter bough from ebay and it didnt work, but im not sure if it is just because its cheap and the adapter doesnt work or if it is that the port isnt obd2 compliant
    also if it isnt obd2 compliant what is it used for and is there a scanner that does work on it?
    Nov 2018
    norway
    1997 bmw e39 520i
    i guess no one knows the answer...
    Canada
    750 F01, 850i, LR3 HSE
    BMW 1996 onward were OBD2 compliant. For the early E39 there should be a cover at the left knee trim panel that you have to remove with a flat screwdriver or coin, under this cover is the OBD2 port.
    Apr 2018
    Roma, IT
    2010 E61
    Just use INPA with a laptop and the round adapter.
    Nov 2018
    norway
    1997 bmw e39 520i
    i just bought a cable to do that, hope it works. i did buy a second scanner that works though its a foxwell nt510 i think. i dont know why 1 works and the other doesnt i use the exact same cable and the same obd-port. maybe the foxwell has a special proram in it since i need to click bmw and not obd to scan it. i also checked the pins in my 20-pin obd port and it doesnt have a 15-pin so its not ADS. again my fingers are crossed for the new cable since i need to program some stuff
    Jul 2004
    Houston, TX
    36 Cylinders
    The 520i with MS41 ecu is K-line, so it will still read with OBD tools (and adapter), but some other modules (like ABS or instrument cluster) would need ADS.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. bmw e39 1997 trans fluid
    By ratswrath134 in forum 1996 - 2003 (E39)
    Last Post: 07-13-2019, 12:00 AM
  2. bmw e39 1997 trans fluid
    By ratswrath134 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-25-2011, 12:37 AM
  3. BMW e39, 1998 520i, automatic
    By nichitanarcis in forum 1996 - 2003 (E39)
    Last Post: 11-13-2009, 12:17 AM
  4. BMW E39 1997 540I needs TLC $1750
    By crafty in forum 5 series & 6 series
    Last Post: 06-09-2009, 01:12 AM
  5. Bmw E39 1997-2002 Abs Front Lip For Sale::::
    By MJW7800 in forum BMW Parts For Sale
    Last Post: 02-12-2006, 08:52 PM
