Results 1 to 6 of 6
Thread: 323i
    Nov 2018
    North Carolina
    2000 Bmw 323i
    323i
    Hello I have a 2000 323i. As I drive the car sometimes when I’m going down a hill I set the car in neutral since it’s a 5 speed manual, but the problem is that the oil,battery,abs and Check engine turn on and then the car shuts off. After a short while I turn it back on and then if feels like it looses power. What can I do to fix this?
    Apr 2015
    Netherlands
    2000 E46 328i
    In a manual car as a general practice it's better to go down hills in gear. It makes the car easier to control and uses less fuel.
    But aside from that, sounds like you have a problem with the idle. Any other complaints, like does it stall at traffic lights or any warning lights on the dash? Does it normally idle nicely?
    Nov 2018
    North Carolina
    2000 Bmw 323i
    Yes it has shut off at stop lights as well and it idle very smooth even after it shuts off, I was thinking about changing the crank and can shafts postition sensors but I not sure if that will help.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the engine computer (DME) for codes. You likely have vacuum leaks. Find a reputable indie shop that specializes in bimmers at www.bimrs.org and have the shop smoke test the intake.
    Nov 2018
    North Carolina
    2000 Bmw 323i
    I will try this thanks @MarcoZandrini
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You’re welcome.
  1. How do I install clear corners on my 2000 323i?
    By trkmedic69 in forum 1999 - 2006 (E46)
    Last Post: 05-07-2008, 10:41 PM
  2. How should I upgrade the H/K system in my 2000 323i?
    By trkmedic69 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-24-2001, 01:38 AM
  3. Stuff from my 98 323IS for sale!!
    By Dean in forum BMW Parts For Sale
    Last Post: 06-20-2001, 11:57 PM
  4. Fs: 98 323is Avus Blue
    By anthonybrennan323 in forum BMW Parts For Sale
    Last Post: 05-05-2001, 02:01 PM
  5. ready to buy shocks for my 323is (need advice)
    By Dean in forum 1991 - 1999 (E36)
    Last Post: 04-30-2001, 07:21 PM
